I am relatively new to OpenHab, and trying to use a proxy for the first time. I have a sensor whose state I need to read by polling it periodically via a command-line script. I want to take my polled state and convert it into a regular “sensor” so I can write straightforward rules. I’ve been reading about proxies in these forums and it seems like a good approach. I’ve made a few attempts shown below. In the first one I created a proxy “switch”, in the second a proxy “sensor”, and in the third a proxy “string”. In each case, my logs clearly show that my sensor is being properly read from the command-line poll, but my proxy rules are not firing.
Try #1 - proxy switch:
Item:
Switch GarageDoorSwitch "Garage door open [%s]"
Rules:
/* Check for switches open every second */
rule "Check hard-wired switches"
Time cron "* * * * * ?" // every second
val String gpioState = executeCommandLine("/opt/openhab/configurations/scripts/checkGpio.sh@@18", 100)
if (gpioState == "CLOSED") {
logInfo("Check hard-wired switches", "Garage door is currently closed: {}", gpioState)
GarageDoorSwitch.sendCommand(OFF)
}else{
logInfo("Check hard-wired switches", "Garage door is currently open: {}", gpioState)
GarageDoorSwitch.sendCommand(ON)
/* Rules for proxy switch */
rule "Garage door is open"
GarageDoorSwitch received command ON
logInfo("Garage door", "Garage Door NEWLY OPENED!")
rule "Garage door is closed"
GarageDoorSwitch received command OFF
logInfo("Garage door", "Garage Door NEWLY CLOSED!")
Try #2 using a Contact:
Item:
Contact GarageDoorOpen "Garage door open [%s]"
Rules:
GarageDoorOpen.sendCommand(CLOSED)
}else{
GarageDoorOpen.sendCommand(OPEN)
GarageDoorOpen changed to OPEN
GarageDoorOpen changed to CLOSED
Try #3, Proxy as a String
Item:
String GarageDoorProxy "Garage door open [%s]"
Rules:
GarageDoorProxy.postUpdate(gpioState)
}else{
rule "Garage door has changed"
GarageDoorProxy updated
logInfo("Garage door", "Garage Door is NEWLY: {}", GarageDoorProxy)
In all cases, the log shows:
2016-10-22 16:59:10.119 [INFO ] [.m.s.Check hard-wired switches] - Garage door is currently closed: CLOSED
2016-10-22 16:59:11.107 [INFO ] [.m.s.Check hard-wired switches] - Garage door is currently open: OPEN
2016-10-22 16:59:12.108 [INFO ] [.m.s.Check hard-wired switches] - Garage door is currently open: OPEN
2016-10-22 16:59:13.108 [INFO ] [.m.s.Check hard-wired switches] - Garage door is currently open: OPEN
2016-10-22 16:59:14.108 [INFO ] [.m.s.Check hard-wired switches] - Garage door is currently open: OPEN
2016-10-22 16:59:16.117 [INFO ] [.m.s.Check hard-wired switches] - Garage door is currently closed: CLOSED
I’m sure it’s something basic… thanks. -Ken
