First command to Yeelight bulbs gets lost
I see something strange with my Yeelight binding.
I use a 2.5 snapshot binding because I want to send dedicated commands to the lights.
My Yeelight bulbs are in a switched circuit together with normal bulbs.
I seems that the first command that I send to the lamps always gets lost?
Everything is processed correctly from the second command.
Between powering the Yeelight bulbs and the first command there is a waiting time of at least 10 minutes to give the Yeelight bulbs the time to connect to the WiFi and Openhab.
Is this a issue of the binding?
Check github here to look thru yeelight issues. Be sure to check not only open issues but the closed ones as well. If no luck with a solution then open an issue.
