I just installed openHAB2 for the first time.
Windows 10 64bit on my dedicated home media server. 192.168.1.11
The server has no monitor, keyboard nor mouse, i access it through Windows RDP on another machine.
I installed java and set the environmental variable on the server.
I got a java error “server-mode unavailable” / install java development kit.
followed other instructions in the ISSUES section of github.
uninstalled all java, only installed java dev kit 32bit.
made sure environmental variable pointed to it.
ran openHAB2 again.
no error. looks like it is running.
open chrome (tried edge too)
localhost:8080 - invalid request - (tried from server localmachine)
192.168.1.11:8080 - invalid request - (tried from server and other pcs on network)
I cannot proceed with the installation.
re-run with debugging…
says Listening for transport dt_socket at address: 5005
tried localhost:5005
the page did not load
“This page isn’t working/192.168.1.11 didn’t send any data. ERR_EMPTY_RESPONSE” but it triggered a response in the openhab terminal window.
Debugger failed to attach: handshake failed - received >GET / HTTP/1.1< - expected >JDWP-Handshake
localhost:8080 still returns “invalid request”, but does not trigger a response in the openhab terminal window…
here is links to the logs. they are too big to copy paste
without debugging
https://drive.google.com/open?id=1G0fh3Au0GaEExBrgU2VchCVpYdxkz-bp
with debugging
https://drive.google.com/open?id=1kRrFu1CHmWk_AYqJjzw-mADdGiK3O3V8
- Platform information:
- Hardware: AMD Phenom II X6 1090T
- OS: Windows 10 64bit
- Java Runtime Environment: jdk1.8.0_161
- openHAB version: 2.2 and 2.3
- Issue of the topic: please be detailed explaining your issue
- Please post configurations (if applicable):
- Items configuration related to the issue
- Sitemap configuration related to the issue
- Rules code related to the issue
- Services configuration related to the issue
- If logs where generated please post these here using code fences:
