Java Runtime Environment: unknown, but its from 2017
openHAB version: 2.2
Hey guys,
I’ve been reading a lot in your community but I’am really confused about the configuration now.
Current state: Some FS20 components and Somfy RTS Window shutters and Warema EWFS in the wintergarden.
Future plans if the first steps work fine: Homematic in some other rooms, MAX! for the heating radiators.
So I’ve set up openHAB2.2 on Windows. This is working fine (icloud binding, astro binding, weather binding). Now I’m about to order a nanoCUL 868 to start controlling the FS20 components. As far as I know the FS20 binding is for OH1 (1.10.0) so the configuration has to be done by hand. I’ve created the fs20.cfg with the following content:
fs20:device=serial:/dev/ttyACM0
and used SmartHome Designer for creating FS20.things with:
Am I right after ordering the nanoCUL 868 I just plug it to the USB of the Windows 10 Computer and install a driver to use it with OH?
I think this:
serial:/dev/ttyACM0
is for unix systems. How do i get the path for windows? Do I need a fs20.cfg in /conf/services oder just a fs20.things in /conf/things?
Would be nice if you can give me some advise and I can start beeing part of the OH-Community. Iam just a student and it would be mad if i spend the money for the nanoCUL (even if its just 35€) and it does not work.
nanoCUL and FS20 / FHT is a frustrating combination.
It does not work… Something is different to a original Busware CUL.
With a Busware CUL my setup works as it should.
With my nanoCUL (working perfect with FHEM!) it doesnt.
Only if it deinstall install reconfig all with no sytem and logic the bindings
it starts working until next reboot. Then the mess starts again.
If it starts it is working reliable!
So save money and buy for working config a Busware CUL
The firmware of my nanoCUL is 1.67. The Busware is 1.67 too…
I have tried many combinations of Binding Versions for Cul transport serial fht fs20 (1.10, 1.11 and snapshot Version 1.12)
I have no problem with the access of the USB port. I have a symlink in rules defined. So it is sure that OpenHab get access to the correct port
The setup that doesnt work generates no error in any log file and log debug in karafe shows no errors
So, today my original! Busware CUL V3 was delivered.
I’ve pluged it to the USB Port and was trying to install the driver delivered with DFU-Programmer and Windows 10 said the best driver is already installed.
Then I converted my FS20 Housecode and added the livingroom, the content of my fs20.items:
Switch Kueche "Kueche Schalter" { fs20="2D780F" }
and the Code in my fs20.cfg in conf/services
fs20:device=serial:COM4
I’ve deleted the fs20.things.
Now I’ve configured a Switch in HabPanel with the “Kueche Schalter”. If I touch it on my phone the CUL does one or two extra blinks of the green led.
So it doesn’t work, do you can see my failure?
Best regards,
Flo
Do you mean the openhab.log?
It says the following:
2018-02-23 13:50:05.783 [INFO ] [er.internal.HomeBuilderDashboardTile] - Started Home Builder at /homebuilder
2018-02-23 13:50:07.265 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://192.168.178.168:8080
2018-02-23 13:50:07.266 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://192.168.178.168:8443
2018-02-23 13:50:11.231 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'fs20.items'
2018-02-23 13:50:12.581 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-02-23 13:50:13.655 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2018-02-23 13:50:13.702 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2018-02-23 13:50:13.834 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2018-02-23 13:50:13.979 [WARN ] [io.transport.cul.CULLifecycleManager] - CUL config is NULL, doing nothing
The events log:
2018-02-23 13:40:40.868 [ome.event.ItemCommandEvent] - Item 'Wohnzimmer' received command ON
2018-02-23 13:40:40.873 [vent.ItemStateChangedEvent] - Wohnzimmer changed from NULL to ON
2018-02-23 13:40:43.184 [ome.event.ItemCommandEvent] - Item 'Wohnzimmer' received command OFF
2018-02-23 13:40:43.187 [vent.ItemStateChangedEvent] - Wohnzimmer changed from ON to OFF
2018-02-23 13:40:44.973 [ome.event.ItemCommandEvent] - Item 'Wohnzimmer' received command ON
2018-02-23 13:40:44.974 [vent.ItemStateChangedEvent] - Wohnzimmer changed from OFF to ON
2018-02-23 13:40:47.552 [ome.event.ItemCommandEvent] - Item 'Wohnzimmer' received command OFF
2018-02-23 13:40:47.553 [vent.ItemStateChangedEvent] - Wohnzimmer changed from ON to OFF
2018-02-23 13:40:50.567 [ome.event.ItemCommandEvent] - Item 'Wohnzimmer' received command ON
2018-02-23 13:40:50.571 [vent.ItemStateChangedEvent] - Wohnzimmer changed from OFF to ON
2018-02-23 13:42:44.645 [ome.event.ItemCommandEvent] - Item 'Wohnzimmer' received command OFF
2018-02-23 13:42:44.647 [vent.ItemStateChangedEvent] - Wohnzimmer changed from ON to OFF
2018-02-23 13:43:09.159 [ome.event.ItemCommandEvent] - Item 'Wohnzimmer' received command ON
2018-02-23 13:43:09.161 [vent.ItemStateChangedEvent] - Wohnzimmer changed from OFF to ON
2018-02-23 13:43:10.216 [ome.event.ItemCommandEvent] - Item 'Wohnzimmer' received command OFF
2018-02-23 13:43:10.216 [vent.ItemStateChangedEvent] - Wohnzimmer changed from ON to OFF
2018-02-23 13:43:11.326 [ome.event.ItemCommandEvent] - Item 'Wohnzimmer' received command ON
2018-02-23 13:43:11.328 [vent.ItemStateChangedEvent] - Wohnzimmer changed from OFF to ON
2018-02-23 13:43:13.511 [ome.event.ItemCommandEvent] - Item 'Wohnzimmer' received command OFF
2018-02-23 13:43:13.512 [vent.ItemStateChangedEvent] - Wohnzimmer changed from ON to OFF
Did you have activated “Include Legacy 1.x Bindings” in Configuration/System (Paper UI)?
For my understandig it should do without that, but it doesnt if i dont use this option.
u both are genius.
I was going downstairs for testing and switched the lamp switch. But I was in the living room and forgot that I’ve configured the Kitchen. I just heared a “click”. Then I’ve went to the kitchen and it is working!
I’ve made a clean install earlier this morning and forgot to active 1.x bindings.
For general testing of the CUL. Use a terminal program
Type: V Enter
You should see the Firmware Version of the CUL
Type: X61 + Enter (Uppercase X!!) Communicate verbose Details
Press a button on your FS20 Remote. Now you must become a message.
If that works Type: X21 Enter -> normal modus
Okay got it. Just X05 and it is listening and shows the HEX of the remotes.
So there ist just a little Problem. I Have a 4x Switch in the garden, the HEX is A3E802. This works but in reverse. If I switch on it turns off, if I switch off it turns on. Also the received command is
FA3E80200 for on
and
A3E80201 for off
at the FS20S8 remote control.
but it should be 00 for off and 01 for on, otherwise on HABPanel it shows On but it is Off.
Do you have some advise?
Edit: And an additional question. I’m using a 2x Switch for the garage. The command is FD9955512 because it is a toggle. How can I use this toggle in Openhab. If I use a switch it doesn’t work.
Little Correction. I’m using 1x Switch with Timerfunction for the garage.
The Codes are FA3E81112 and FA3E81012. The channels on the remote are doubled. So one is for on and off. How can I use it in OpenHAB? Is there anything else then Switch as Item? Maybe Toggle?
Also there is this problem above for the garden. in Basic UI I can map ON=OFF and OFF=ON but how to use this mapping in HABPanel?
