Is it working properly yet my hive and openhab connection is still useless never works this is the main part of my smart home I need too fix it works when openhab first starts but soon looses its connection
@Sharpy I made some changes in that binding, fixed a few things. Especially, the issue with authentication was broken. I’ll share once tested properly.
I don’t have any of those to test. If you have seen some docs that describe the API calls and how to control those devices, I can have a look whether it is possible to add.
I’ve just managed to get back to looking at this. @jamborta have you brought the source up to the new build system or just made functional changes? There were some things in the PR that I need to change before it is accepted as well.
I’m not actually sure what you need here api calls are not something I am very experienced with tbh.
I don’t own any TRV Valves either I was waiting on this binding getting fixed before dropping more money on any hive systems as the thermostat already feels like an expensive paper weight with it not communicating properly with OH
But looking on Google there is a few things around maby you can find something here
Hi again @ChrisSFoot same question do you think TRV Valves will ever be supported
So your version does not communicate over the WAN its all LAN based now?
@Sharpy I’ll certainly give it a go! I don’t have one to play with but I wasn’t actually aware they existed yet, I can see my credit card heating up already…
Might not be worth it tbh a quick Google search for Hive trv problem reveals quite a bit I doubt they could still charge over £50 for an inferior product tho
Hopefully, Im the same I have also been interested in individual controll over radiators myself but dont want too drop money into it without OH support
I don’t use apps too controll my devices openhab automates it all so I have just left it for now
Looks like i’ve got a busy weekend ahead of me getting this all sorted. Fingers crossed they haven’t changed the api too much to introduce the trvs. What features do you actually need out of the binding?
I’m still struggling with the binding dropping its connection too the Hive thermostat so anything would be a major improvement for me at the moment
Main requirements
What is the thermostat set at and is it heating?
ability too change temperature set on Thermostat
Like I said in previous posts the binding is perfect for me as it stands its just the authentication error that blocks OH from talking too HIVE the only thing that makes this work again is a full System restart of OH it then works for 5 mins or so as expected then drops out again
As for radiator trvs basic open Close and temps would be good
