Fish.audio Text-to-Speech (voice add-on)
fish.audio Text-to-Speech (voice add-on)
A TTS service for openHAB 5.2 that speaks through fish.audio’s API with the voice
models you name in a secrets file, falls back to Google Translate’s voice when fish.audio does not answer,
and gives rules a fire-and-forget way to speak through any audio sink. Written for a house that wanted
HAL 9000 on its Sonos players; it works with any fish.audio voice model and any openHAB audio sink.
What is new in 1.0.1
  • Sink guard. With a Sonos player on a music-service queue (Spotify on a Playbar, measured), the Sonos
    binding’s notification sometimes leaves the player stopped at the announcement volume, or resumes it at
    volume 2. The add-on now reads the player’s state and volume before the clip (through the items linked to
    the sink thing’s state, volume and control channels), waits two seconds after it, and then puts the
    volume back and sends PLAY if the music did not come back by itself. On by default (sinkGuard); a sink
    that is not a thing is left alone.
Features
  • fish.audio voices: every model in the secrets file’s voices list becomes a voice fishaudio:<id>,
    each with its own language, speed and model when they differ from the file’s; mp3 at 128 kbit
  • Google Translate fallback: when fish.audio fails (no credit, token, outage) the same text is spoken by
    Google’s voice in a configurable language, so no announcement is lost; fishaudio:google-da and
    fishaudio:google-en are also voices of their own, with no fish.audio call
  • Say item: a command to a String item - JSON {"text", "voice", "sink", "volume"} or plain text - is
    spoken on the add-on’s own worker thread, in order. A rule is free at once. (Voice.say() itself returns
    only when a Sonos sink has played the clip and restored the volume, which holds the rule file’s lock for
    the whole clip; this item is the way around that)
  • Error item: HTTP <code> at <time> / no api_key at ... / no answer at ... on a failed call, so a
    rule can mail you
  • openHAB’s TTS cache: every clip is kept per text and voice; a repeated line costs no credit
  • Nothing secret in the UI: the API key and voice ids live in a file openHAB can read; the file is
    re-read when it changes, so a new voice is one edit, no restart
  • 23 JUnit tests
Requirements
  • openHAB 5.2, Java 21
  • A fish.audio account with prepaid API credit (the API is paid, pay-as-you-go, no subscription - see Cost), an API key, and the reference_id of at least one voice model
  • An audio sink (the Sonos binding’s players, webaudio, enhancedjavasound, …)
Getting an API key and a voice
  1. Create an account at fish.audio and open Get Started | Fish Audio | Best AI Text To Speech & Free Voice Cloning;
    click Get your API key. The key is shown once; copy it into the secrets file as api_key. Existing keys are
    managed at API Keys | Fish Audio | Best AI Text To Speech & Free Voice Cloning. Never put the key in a .things file, a rule or git.
  2. Top up API credit in the same developer area (the API is pay-as-you-go, see Cost).
  3. Pick a voice: open any voice on fish.audio; its page is https://fish.audio/m/<model-id>, and the model id (also
    behind the copy button on the voice page) is the reference_id. Your own cloned voice works the same way.
Configuration
Create the secrets file (default /etc/openhab/secrets/fish-audio.json, readable by the openhab user,
640):
{"api_key": "...", "reference_id": "<voice model id>", "model": "s2.1-pro", "language": "en", "speed": 0.9}
or, for more than one voice:
{"api_key": "...", "model": "s2.1-pro", "speed": 0.9, "voices": [
  {"id": "hal9000", "label": "HAL 9000", "reference_id": "...", "locale": "en-US", "language": "en"},
  {"id": "nanna",   "label": "Nanna",    "reference_id": "...", "locale": "da-DK", "language": "da", "speed": 1.0}]}
A bare reference_id becomes the voice fishaudio:hal9000 (en-US). The file wins over the UI for model
and speed; a UI apiKey wins over the file.
Settings → Voice → fish.audio Text-to-Speech:
Parameter Default Description
secretsFile /etc/openhab/secrets/fish-audio.json The file above
apiKey - Overrides the file’s key
apiUrl https://api.fish.audio/v1/tts
model s2.1-pro fish.audio model, unless the file or the voice says otherwise
speed 0.9 Prosody speed, same precedence
mp3Bitrate 128
timeoutSeconds 30
fallbackGoogle true Speak through Google Translate when fish.audio fails
fallbackLanguage da Google’s language for the fallback
errorItem FishAudio_LastError String item that gets the error text
sayItem FishAudio_Say String item whose commands are spoken
sinkGuard true Put the sink’s volume back and resume its music after the clip
sinkGuardSettleSeconds 2 How long to give the sink’s own restore first
The service can be the default TTS (Settings → Voice).
Quick Start
fishaudio.items
String FishAudio_Say       "Say [%s]"        <speaker> { autoupdate="false" }
String FishAudio_LastError "TTS error [%s]"  <error>
Rule (JS Scripting)
// fire and forget: the add-on speaks it on its own thread; the rule is free at once
items.getItem('FishAudio_Say').sendCommand(JSON.stringify({
  text: 'Good evening. The front door is open.',
  voice: 'fishaudio:hal9000',
  sink: 'sonos:One:kitchen',
  volume: 45
A plain text command uses openHAB’s default voice and sink. From a terminal, the voice REST works too:
curl -s -X POST -H 'Content-Type: text/plain' --data 'Hello' \
  'http://localhost:8080/rest/voice/say?voiceid=fishaudio:hal9000&sinkid=sonos:One:kitchen&volume=45'
curl -s http://localhost:8080/rest/voice/voices lists the voices the add-on registered.
Cost
fish.audio’s API is paid, pay-as-you-go: no subscription is needed, but the account must hold
prepaid API credit (the web plans’ monthly credits are a different purse). The price list
(docs.fish.audio, read 2026-11-01) bills text-to-speech per million UTF-8 bytes of input text:
s2.1-pro and s2-pro 15 USD, s1 15 USD (retires 2026-12-31), drama-3 50 USD, and a
s2.1-pro-free model listed at 0 USD (what it limits is not stated on that page; set model to try
it). One English character is one byte, Danish æøå are two, so a one-sentence announcement of
about 100 characters costs around 0.15 US cent with s2.1-pro; openHAB’s TTS cache keeps every
clip, so a line that repeats costs nothing the second time. When the credit is gone, fish.audio
answers HTTP 402; the add-on writes it to the error item and speaks through Google Translate instead
(free, no key). Watch the balance from a rule if it matters: GET /wallet/self/api-credit with the
same API key returns it.
What it does not do
  • It does not split long texts for the Google fallback (about 200 characters per request). Keep lines short.
  • It does not choose rooms or quiet hours; that is your rules.
Resources
