Hello together,
I am not a developer, so I am not really good at finding and fixing problems.
But in the most cases I can fix it by my self.
But actual I have a Problem, where I need your help.
I have some danfoss-LC13 and a MAX!Cube with a MAX!Basic thermostat.
If I change the temperature via PaperUI it worked for each thermostats. But if I try to use HABPanel, the temperature variable is changed, but there is no command send to the thermostat.
[ItemStateChangedEvent ] - max_thermostat_LEQ043XXXX_MEQ145XXXX_set_temp changed from 20 to 18.5
[ItemStateChangedEvent ] - max_bridge_LEQ043XXXX_duty_cycle changed from 6 to 9
[ItemCommandEvent ] - Item 'max_thermostat_LEQ043XXXX_MEQ145XXXX_set_temp' received command 18.5
Look at the end there is an
max_bridge_LEQ043XXXX_duty_cycle changed from 6 to 9.
If I trigger the same via a dimmer and the HABPanel, it has no effct.
[ItemStateChangedEvent ] - max_thermostat_LEQ043XXXX_MEQ145XXXX_set_temp changed from 18.5 to 19.5
My rule look like:
rule "Temperatur im Schlafzimmer erhöhen / verringern"
Item Soll_Temp_Dimmer_SZ received command
if ((receivedCommand==INCREASE) || (receivedCommand==DECREASE)) {
var Number temp = 0
temp = max_thermostat_LEQ043XXXX_MEQ145XXXX_set_temp.state
if(receivedCommand==INCREASE) temp = temp + 1
if(receivedCommand==DECREASE) temp = temp - 1
postUpdate(max_thermostat_LEQ043XXXX_MEQ145XXXX_set_temp, temp);
Does anybody have an idea, why this isn`t working?
Thank you.
