blablavaüpkfdgpokasdpfmasldmgknamfsgnadobfng üoe bfvüoaef ntüo
First things first, please use the code fences
Second thing,read the docs…
Straight out of the docs:
Rollershutter Raffstore { http=">[*:POST:http://hp27/deviceajax.do?cid=9&did=1010042&goto=%2$&command=0]" }
Ok:
Try:
">[*:POST:http://hp27/deviceajax.do?cid=9&did=1010042&goto=%1$s&command=0]" }
or
">[*:POST:http://hp27/deviceajax.do?cid=9&did=1010042&goto=%2$s&command=0]" }
Read the docs…
See the tutorial:
Please mark the thread as solved.
Tick the solution mark under the post that gave you the solution
I read the doku but it does not work, the binding is not in the sitemap…only in the habpanel
Switch item=Raffstore label=“Raffstore” icon=“rollershutter” mappings=[UP=“Hoch”, STOP=“X”, DOWN=“Runter”]
this is my Sitemap
I have it
