Germar
(Germar)
#1
I just recognized that the FMI Weather Binding was in state COMMUNICATION_ERROR
with following message:
FMIExceptionReportException: Exception report (OperationParsingFailed): [No handler for ‘fmi::forecast::hirlam::surface::point::multipointcoverage’ found!, URI: /wfs?endXXXXXXXX¶meters=Temperature%2CHumidity%2CWindDirection%2CWindSpeedMS%2CWindGust%2CPressure%2CPrecipitation1h%2CTotalCloudCover%2CWeatherSymbol3&request=getFeature&service=WFS&starttime=2022-11-04T15%3A40%3A00Z&storedquery_id=fmi%3A%3Aforecast%3A%3Ahirlam%3A%3Asurface%3A%3Apoint%3A%3Amultipointcoverage×tep=20&version=2.0.0]
By searching for that error message I found out that FMI has announced that it will stop using the HIRLAM weather forecast model in October 2022. It will be replaced by the HARMONIE model. Is there a way to configure the used model? I did not found any. Maybe it is hard-coded?
masipila
(Markus Sipilä)
#4
We noticed the same with @ruxu… We don’t use the binding but a custom javascript to fetch the forecast. Rainer updated the script to use the current HARMONIE model, see Control a water heater and ground source heat pump based on cheap hours of spot priced electricity - #113 by ruxu
If the maintainer of the FMI Binding reads this, that link might be helpful.
Cheers,
Markus
I have adjusted the binding to use the HARMONIE model: [FMI] HIRLAM → HARMONIE weather model by nils · Pull Request #13693 · openhab/openhab-addons · GitHub
Unfortunately it looks like only “northern Europe” is supported by the new HARMONIE weather model.
In Northern Europe, the HARMONIE (MEPS) weather forecast data can be used as a replacement weather forecast model.
(source)
This is confirmed by trying to get data for Stuttgart, Germany:
No data available for ‘Akademiegarten’!
Data for Hamburg, Germany is available however.
Germar
(Germar)
#6
Great! Thanks a lot! I’ll test it tomorrow
Hi @Germar,
if you are lucky your location is still supported
You can try this: JFrog
Germar
(Germar)
#8
My location is still supported and the patched binding works like a charm! Thanks a lot.
