- Platform information:
- Hardware: 64bit x86 Intel, 6GB RAM, 2TB HDD
- OS: Windows 10
- Java Runtime Environment: Zulu JDK 11
- openHAB version: 3.2.0 stable
- Issue of the topic:
- Battery % item with JS transformation from voltage showing with units “V” in item page widget (which I believe is standalone widget) but shows correctly in item list page (Settings → Items, which I believe is list widget) and
- Please post configurations (if applicable):
- Humidity sensor Thing configuration
UID: HumiditySensor
label: Humidity Sensor
thingTypeUID: mqtt:topic
configuration: {}
bridgeUID: mqtt:broker
channels:
- id: HumiditySensor_BatteryVoltage
channelTypeUID: mqtt:number
label: Battery Voltage
description: ""
configuration:
postCommand: false
unit: V
min: 3
stateTopic: Humidity Sensor/Battery
max: 4.2
- Humidity sensor Battery Voltage Item configuration
Label: Battery Voltage
Type: Number:ElectricPotential
Category: battery
Semantic Class: Measurement
Semantic Property: Voltage
- Humidity sensor Battery Percent Item configuration
Label: Battery Percent
Type: Number
Category: batterylevel
Semantic Property: None
- Battery Percent Item to Thing Link
Profile: JS
Profile Configuration: | (((parseFloat(i) - 3)/0.012) + 0).toFixed(1) + "%"
With this configuration:
- Battery Voltage shows (eg) 3.536 V
- Battery Level shows 44.7 % in Settings → Items and Analyze chart, but 44.7 V in almost all other UI, eg:
- overview UI, Settings → Items → Battery Percent, etc
If I remove “unit: V” from thing definition, item value starts showing “UNDEF” in UI.
Any recommendations to make this shows “%” units everywhere.
