vavo01
(Valentin Voth)
October 21, 2019, 11:25am
1
Hi Folks,
Since the update of the android app to v 2.8.0 slider and setpoints deliver the value in float format instead of integer.
Since the new update of the Android OpenHAB app version 2.8.0 (August 1st, 2019) my slider items for shutter (“Rolladen”) are not working anymore. In previous versions, everything worked fine!!!
Excerpt of my .items file are attached below:
//–> Rolläden[0/x/x] {knx="LZ, KZ, Position+<Position_Rückmeldung}
//–> UG Wohnen [0/2/x]
Rollershutter RUGWohnenWest “UG Wohnen West Rolladen [%d %%]” (gWohnenUG, gRollo) {knx = …
The tahoma binding, I use for my blinds and rollershutters, goes offline if it has to deal with floats.
My question is, how can I force the slider or setpoint send integer format?
I had a similar issue with my speaker connected via http binding.
Have you tried updating to 2.9? This solved at least my problem
rossko57
(Rossko57)
October 21, 2019, 5:09pm
3
If you read the linked thread, it tells you -
A) it’s a binding bug really. If you create a github isdue for the binding, it could get fixed properly.
B) as a temporary workaround, the android app author has made a new app version
C) if you like neither suggestion, you can use a proxy Item on your UI and have a rule update your bound Item with an integer
vavo01
(Valentin Voth)
October 21, 2019, 6:41pm
4
Sorry if I’ve written some mistakable.
I see that the binding has troubles with float numbers. But I’m just searching for a lazy solution. A kind of formater for sitemap values?
The next step will be an issue in github, of course.
vavo01
(Valentin Voth)
October 21, 2019, 6:43pm
5
No, unfortunately not
Still get log messages like
2019-10-21 20:22:35.974 [ERROR] [oma.handler.SomfyTahomaBridgeHandler] - Received error code: 400
2019-10-21 20:22:35.981 [WARN ] [oma.handler.SomfyTahomaBridgeHandler] - Apply command response: {"error":"Managed action group is invalid : setOrientation() : Invalid value for command parameter p1 : expected integer value between 0 and 100 but got 56.0"}
2019-10-21 20:22:35.982 [hingStatusInfoChangedEvent] - 'somfytahoma:onoff:2fd3198a:756a177d-c08d-4a3b-8849-410cecf6eb45' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-10-21 20:22:35.990 [hingStatusInfoChangedEvent] - 'somfytahoma:rollershutter:2fd3198a:82e8153b-49e1-49f6-9979-818c13dfdfb1' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-10-21 20:22:35.994 [hingStatusInfoChangedEvent] - 'somfytahoma:rollershutter_silent:2fd3198a:14b3fa15-e075-46c5-829a-73a14c5c247d' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-10-21 20:22:35.997 [hingStatusInfoChangedEvent] - 'somfytahoma:rollershutter_silent:2fd3198a:77db2aee-6e1c-4afb-9f02-7e4f1b854bdf' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-10-21 20:22:36.001 [hingStatusInfoChangedEvent] - 'somfytahoma:rollershutter:2fd3198a:5e7ee3ea-6e7e-4983-abff-6f294828b05c' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-10-21 20:22:36.006 [hingStatusInfoChangedEvent] - 'somfytahoma:rollershutter_silent:2fd3198a:07b4622a-d371-429c-9403-9dd34dc128ff' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-10-21 20:22:36.010 [hingStatusInfoChangedEvent] - 'somfytahoma:rollershutter_silent:2fd3198a:b536e676-9e01-4f9a-befc-e0f09aff569d' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-10-21 20:22:36.021 [hingStatusInfoChangedEvent] - 'somfytahoma:exteriorvenetianblind:2fd3198a:178ea6e5-89db-4fe7-abd3-da4ad2a2001f' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-10-21 20:22:36.031 [hingStatusInfoChangedEvent] - 'somfytahoma:exteriorvenetianblind:2fd3198a:9154d2af-3abd-4838-bca4-d1e9eb68ed52' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-10-21 20:22:36.034 [hingStatusInfoChangedEvent] - 'somfytahoma:exteriorvenetianblind:2fd3198a:95775f93-fa03-4894-94e5-1939151e6db5' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-10-21 20:22:36.037 [hingStatusInfoChangedEvent] - 'somfytahoma:exteriorvenetianblind:2fd3198a:81c85ddd-16c8-4164-a0c6-04e0337edf3b' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-10-21 20:22:36.040 [hingStatusInfoChangedEvent] - 'somfytahoma:exteriorvenetianblind:2fd3198a:6204a9d6-b90e-401a-94cf-15b83e6d4fae' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-10-21 20:22:36.042 [hingStatusInfoChangedEvent] - 'somfytahoma:exteriorscreen:2fd3198a:27a6e1b8-2e52-43da-ae8d-58964ca933ca' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-10-21 20:22:36.045 [hingStatusInfoChangedEvent] - 'somfytahoma:exteriorscreen:2fd3198a:deb80813-3108-4667-a961-ad4c3fea750d' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
maniac103
(Danny Baumann)
October 21, 2019, 7:40pm
6
The simplest workaround is defining the item labels in integer format: Number MyItem "My Item [%d]"
But yes, a binding must be able to deal with Number items in both integer and float format … I explicitly asked Kai about that, and he stated so.
