How to I apply number format to a tooltip on a floorplan oh-plan-marker (Need 1 decimal place in example below) ?
I guess you should add a state description to your item definition.
- Open the item definition
- Add Metadata
- State description
- Pattern: %.1f °C.
Hi, How do i add that to an items text file ?
Number Computed_coldRoom_Temperature_SMA5 "Computed Cold Room Temperature SMA (5 mins)" (gComputed)
Look here at state presentation.
This should work, not tested:
Number Computed_coldRoom_Temperature_SMA5 "Computed Cold Room Temperature SMA (5 mins) [%.1f °C]" (gComputed)
