Hi all. I have this rule file sending the values of Hours, Minutes, Day of the Week and Date via MQTT in exactly this fashion to be read by an Arduino somewhere down the line.
The only thing that eludes me is … if the minute or the hour is less than 10 it is missing the leading 0. How can I change the formating of this? I need the hours and minutes as separate values though.
here is the rules I´m using:
import java.util.Date
import java.text.SimpleDateFormat
rule "publish time"
Item LocalTime_DatumUndZeit changed
var hour = (now.getHourOfDay).toString
var minute = (now.getMinuteOfHour).toString
var tag = (now.getDayOfWeek).toString
var SimpleDateFormat df = new SimpleDateFormat( "DD|MM|YY" )
var String NewDate = df.format ( new Date() )
publish("mosquitto", "date", NewDate)
publish("mosquitto", "day", tag)
publish("mosquitto", "timeHour", hour)
publish("mosquitto", "timeMinute", minute)
I am glad to found this topic. After some research - googling a lot I have this (very simple) solution:
rule "Publish mqtt time to ESP8266 LCD"
Time cron "0 * * * * ?"
MqttTime.sendCommand(String::format("%02d:%02d", now.getHourOfDay(), now.getMinuteOfHour()))
log output:
08:49:00.017 [INFO ] [smarthome.event.ItemCommandEvent ] - Item 'MqttTime' received command 08:49
08:49:00.033 [INFO ] [smarthome.event.ItemStateChangedEvent] - MqttTime changed from 08:48 to 08:49
