Formatting items in rules to generate a string
I found the solution at the very end of this post.
String formatting
I want “21.3°C” in my message string, not “21.28478 °C”
var message = "Temperature is " + (tempItemC.state as QuantityType<Temperature>).format("%.1f%unit%")
// returns "Temperature is 10.0°C"
// uses usual Java formatter control string
for speed you can use
+(localTodayWindSpeed.state as QuantityType<Speed>).format("%.1f %unit%")
