Forum search for avm!fritz binding not possible?
When trying to search for posts of AVM-Binding in the forum I only get this message
This link does not work for you? (from my search)
https://community.openhab.org/search?q=AVM-Binding
Hi Bruce,
thx for fast reply.
When searching this way:
I got the error.
On the other hand, when I tried to create this post, I couldn’t use the tag “avm!fritz”. When trying to send the post a message “Internal Server error” came up. When deleting this tag (only using “beginners”) my post was accepted and sent.
As I have some problems with my AVM-Binding under 2.5.0.M3, I want to look if there are others with similar problems with a “global search”.
I used the magnifying glass in the upper right to search.
I understand how you searched, but the result is nor very great. I thought it could be better to use the other way for more results, but failed. And before creating a new topic with my problems, I want to find out if there is a solution.
With other tags (mqtt, zwave, homeatic, etc.) it works normal.
So it’s very funny. I don’t want to create a new topic for my real problem, but have to create a new topic on how to find certain topics, isn’t it ? :crazy_face:
Any comments, @Kai? I think you handle some of the forum software.
It may be because of the special character ! in the tag
Not every (only a few) actually put a tag on their threads
I wouldn’t restrict my search to tagged threads if I were you
Thx,for your hint Vincent.
Even if I use “avm”, avmbinding" or “avm-binding” (suggested tags) ends up in the same result.
@fibu-freak
You could use this openhab search:
https://community.openhab.org/search?expanded=true&q=avmfritz*%20order%3Alatest
Then scroll down to the bottom until you can read: “No more results found.” → 175 hits.
And in the results (175) use the browser search = CTRL+f and fill in avmfritz!binding
Then you will get all 36 tagged topics.
Nice approach.
Will use this as a workaround to look for my problem.
Cheers,
Peter
