Forward tibber energydata via MQTT
Need help sending/fowarding tibber data from an .items file via MQTT.
itemfile:
  • Number TibberTotalPrice “Tibber Total Price” {channel=“tibber:tibberapi:228be1b372:current_total”}
  • String PriceLevel “Tibber Price Level” {channel=“tibber:tibberapi:228be1b372:current_level”}
In my sitemap the data is showing perfect.
Text item=TibberTotalPrice label=Tibber Uurprijs [€ %s ] icon=energy
Text item=PriceLevel label=Prijs Niveau icon=energy
How can I send this data via MQTT.
Broker running with the name:
mqtt:broker:b66440a319
Hope someone can help me :slight_smile:
Use an openHAB Rule to publish the data using mosquitto_pub.
I tried this sollution first:
unfortunately that does not work :frowning:
Please take notes of the date of entries here in the forum! :wink:
The linked thread dates 2016 at times, OH1 was the current version. Many things changed since then! :wink:
Ok, you don’t need to use mosquitto_pub in any way:
  1. install the MQTT binding
  2. add your “MQTT broker” as bridge
  3. add a “Generic MQTT Thing” and configure two channels for your two items
  4. link your existing items to the channels
read more here:
Come back, if you need help.
Thank you all.
I did it with rules and scripts.
Solved for me :slight_smile:
