I am trying to make my sitemap a bit better and would like a top level of my “rooms” to then have some grouping under them. I can do the rooms bit quite simply with this in my sitemap:
Frame {
Group item=Lounge label="Lounge" icon="sofa"
Group item=Kitchen label="Kitchen" icon="kitchen"
Group item=Hall label="Hall" icon="corridor"
Group item=Landing label="Landing" icon="corridor"
And that works well, i get the four rooms and when i click them i get any items i have tagged as that group.
However i cant order the items in that group on the page it loads. Is there a way to link to order or group the items within the group sub-page or link from one to another sitemap for each group (so i can then use frames etc) or do i simply have to put everything on the homepage sitemap for example:
Resulting in what i want but without the sub page. I know i can put the group into the frame and pick up the key things, but ideally i would like to define how the group “page” is displayed.
I did try searching but cant find any examples or anyone doing the same, so a) i am not going mad and b) that is clear…
When you Group on the sitemap you have no control over the order nor can you override the appearance of any of the Items in the Group. You also cannot use things like charts, color, or visibility. In short, except for some quick and easy views of your Items, the Group tag is of pretty limited use.
But you are in luck. You can get the same look/behavior of Group with all the control you want, but you will have to put everything on your sitemap manually.
If you put { } after a Text element it will create a subpage for all the stuff inbetween the {}.
So you could do something like:
Text label="Kitchen" icon="kitchen" {
Frame label="Sonos" {
Default item=Sonos_Kitchen_Controller
Slider item=Sonos_Kitchen_Volume
Switch item=Sonos_Kitchen_Mute
Text item=Sonos_Kitchen_CurrentTrack
Text item=Sonos_Kitchen_State
Switch item=Sonos_Kitchen_LED
Frame label="Lights" {
Switch item=Kitchen_UnderLight
Switch item=Kitchen_MainLight
Note: you can add an item to the Text and have it display the state of that Item as part of the label (e.g. the lights)
@rlkoshak your a legend thank you so much! This works exactly how i wanted it. Even better i just needed to change my top “frame” to a “text” time and it looked like your example and worked!
Not possible and I suspect challenging to implement given it would need to be implemented in ESH Core, BasicUI, ClassicUI, Android App, iPhone App and potentially cause impacts to HABmin and HABPanel.
You might be able to fake something up using an unbound Item and the visibility element.
