I’ve tried the procedure, but same result : no app_token generated.
First I’ve restored my freebox to the factory setting.
Then I’ve removed the freebox thing, and discovered it again.
So the application token was empty, but the binding didn’t create one.
And no message on freebox LCD screen.
Hereafter a copy of the logs (http://openhabianpi:9001/) :
2019-01-19 11:17:31.263 [INFO ] [ry.FreeboxServerDiscoveryParticipant] - Created a DiscoveryResult for Freebox Server freebox:server:fc81d52b3d143c16fdfb1fb6209442c5 on IP 192.168.0.254
2019-01-19 11:17:31.316 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing ‘freebox:server:fc81d52b3d143c16fdfb1fb6209442c5’ to inbox.
2019-01-19 11:17:31.316 [home.event.InboxAddedEvent] - Discovery Result with UID ‘freebox:server:fc81d52b3d143c16fdfb1fb6209442c5’ has been added.
2019-01-19 11:18:10.241 [vent.ItemStateChangedEvent] - neato_vacuumcleaner_GPC16418_F045DA6A5C66_battery_level changed from 99 to 100
2019-01-19 11:18:10.259 [vent.ItemStateChangedEvent] - neato_vacuumcleaner_GPC16418_F045DA6A5C66_is_charging changed from ON to OFF
2019-01-19 11:22:40.063 [me.event.InboxRemovedEvent] - Discovery Result with UID ‘freebox:server:fc81d52b3d143c16fdfb1fb6209442c5’ has been removed.
2019-01-19 11:22:40.228 [hingStatusInfoChangedEvent] - ‘freebox:server:fc81d52b3d143c16fdfb1fb6209442c5’ changed from UNINITIALIZED to INITIALIZING
2019-01-19 11:22:40.243 [hingStatusInfoChangedEvent] - ‘freebox:server:fc81d52b3d143c16fdfb1fb6209442c5’ changed from INITIALIZING to UNKNOWN
2019-01-19 11:22:40.278 [.ItemChannelLinkAddedEvent] - Link ‘freebox_server_fc81d52b3d143c16fdfb1fb6209442c5_reboot-freebox:server:fc81d52b3d143c16fdfb1fb6209442c5:reboot’ has been added.
2019-01-19 11:22:40.291 [.ItemChannelLinkAddedEvent] - Link ‘freebox_server_fc81d52b3d143c16fdfb1fb6209442c5_lcd_orientation-freebox:server:fc81d52b3d143c16fdfb1fb6209442c5:lcd_orientation’ has been added.
2019-01-19 11:22:40.318 [.ItemChannelLinkAddedEvent] - Link ‘freebox_server_fc81d52b3d143c16fdfb1fb6209442c5_wifi_status-freebox:server:fc81d52b3d143c16fdfb1fb6209442c5:wifi_status’ has been added.
2019-01-19 11:22:40.399 [.ItemChannelLinkAddedEvent] - Link ‘freebox_server_fc81d52b3d143c16fdfb1fb6209442c5_xdsl_status-freebox:server:fc81d52b3d143c16fdfb1fb6209442c5:xdsl_status’ has been added.
2019-01-19 11:22:40.412 [.ItemChannelLinkAddedEvent] - Link ‘freebox_server_fc81d52b3d143c16fdfb1fb6209442c5_line_status-freebox:server:fc81d52b3d143c16fdfb1fb6209442c5:line_status’ has been added.
2019-01-19 11:22:41.301 [hingStatusInfoChangedEvent] - ‘freebox:server:fc81d52b3d143c16fdfb1fb6209442c5’ changed from UNKNOWN to OFFLINE (CONFIGURATION_ERROR): App token not set in the thing configuration
Thanks for any help.
Claude
