Freezes openHab
  • Rasperry Pi 3:
    • Hardware: _Rasberry Pi 3 B+
    • OS: _Raspbian GNU/Linux 11
    • Java Runtime Environment:
    • openHAB version: OpenHAB 3.4.2
I’m having a problem with openHab crashing.
Every day it freezes and I can’t use it, it doesn’t respond in browser or app. I need to update Zram to restore functionality. And so almost every day. Additionally, I can’t read the log files via Log Viewer. It does not see the log files. How can all this be fixed?
If use
> log :list
I have this:
openhab> log:list
Logger                                             │ Level
ROOT                                               │ WARN
javax.jmdns                                        │ ERROR
javax.mail                                         │ ERROR
openhab.event                                      │ INFO
openhab.event.AddonEvent                           │ ERROR
openhab.event.ChannelDescriptionChangedEvent       │ ERROR
openhab.event.InboxUpdatedEvent                    │ ERROR
openhab.event.ItemAddedEvent                       │ ERROR
openhab.event.ItemChannelLinkAddedEvent            │ ERROR
openhab.event.ItemChannelLinkRemovedEvent          │ ERROR
openhab.event.ItemRemovedEvent                     │ ERROR
openhab.event.ItemStateEvent                       │ ERROR
openhab.event.RuleAddedEvent                       │ ERROR
openhab.event.RuleRemovedEvent                     │ ERROR
openhab.event.RuleStatusInfoEvent                  │ ERROR
openhab.event.StartlevelEvent                      │ ERROR
openhab.event.ThingAddedEvent                      │ ERROR
openhab.event.ThingRemovedEvent                    │ ERROR
openhab.event.ThingStatusInfoEvent                 │ ERROR
openhab.event.ThingUpdatedEvent                    │ ERROR
org.apache.cxf.jaxrs.sse.SseEventSinkImpl          │ ERROR
org.apache.cxf.phase.PhaseInterceptorChain         │ ERROR
org.apache.karaf.jaas.modules.audit                │ INFO
org.apache.karaf.kar.internal.KarServiceImpl       │ ERROR
org.apache.karaf.shell.ssh.SshUtils                │ ERROR
org.apache.karaf.shell.support                     │ OFF
org.apache.sshd                                    │ WARN
org.eclipse.lsp4j                                  │ OFF
org.jupnp                                          │ ERROR
org.openhab                                        │ INFO
org.ops4j.pax.url.mvn.internal.AetherBasedResolver │ ERROR
org.ops4j.pax.web.pax-web-runtime                  │ OFF
su.litvak.chromecast.api.v2.Channel                │ ERROR
Are your ZRAM file systems running out of room? When it stops responding, ssh to the machine and run dh -h and see if any of the “overlay” file systems are out of space.
Shouldn’t it be:
df -h
Yes it should. :man_facepalming:
In this moment I have this:
openhabian@openhabian:~ $  sudo df -h
Filesystem      Size  Used Avail Use% Mounted on
/dev/root        29G  8.8G   20G  32% /
devtmpfs        454M     0  454M   0% /dev
tmpfs           487M     0  487M   0% /dev/shm
tmpfs           195M   22M  173M  12% /run
tmpfs           5.0M  8.0K  5.0M   1% /run/lock
/dev/mmcblk0p1  253M   50M  203M  20% /boot
/dev/sda3        30G   28K   28G   1% /storage
/dev/zram2      468M  458M     0 100% /opt/zram/zram2
/dev/zram4      468M  458M     0 100% /opt/zram/zram4
tmpfs            98M     0   98M   0% /run/user/1000
/dev/zram1      347M  165M  157M  52% /opt/zram/zram1
overlay1        347M  165M  157M  52% /var/lib/openhab/persistence
/dev/zram16     468M  216K  433M   1% /opt/zram/zram16
overlay16       468M  216K  433M   1% /var/log
but I had to restart zram.
I turn off zram and I have this:
/dev/root        29G  8.3G   20G  30% /
Is ok ?
I can’t use openhab because it keeps crashing. How should I fix it?
Two of your file systems are 100% full I’d start by looking there.
Also, what’s in the logs? openhab.log and the syslog?
I don’t know anything about zram but for comparison here is my output with Zram running;
openhabian@openhab:~ $ df -h
/dev/root        29G  8.5G   19G  31% /
tmpfs           487M  3.1M  484M   1% /run
tmpfs           487M     0  487M   0% /sys/fs/cgroup
/dev/mmcblk0p1  253M   49M  204M  20% /boot
/dev/zram1      469M   57M  377M  14% /opt/zram/zram1
overlay1        469M   57M  377M  14% /var/log
What looks odd are your 2 files that are at 100% do not have an “Overlay” and then they do not go away when you stop zram. Maybe just delete them?
Do they disappear in case the system is booted ? Look like they are a left over.
At the moment, after turning off and on again Zram openhab does not want to start and I have it
/dev/root        29G  8.7G   20G  32% /
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
openhabian@openhabian:~ $ zramctl
NAME        ALGORITHM DISKSIZE   DATA  COMPR TOTAL STREAMS MOUNTPOINT
/dev/zram20 zstd          500M  13.5M 454.5K  656K       4
/dev/zram19 zstd          500M   604K  13.9K  144K       4
/dev/zram16 zstd          500M    38M   4.6M    5M       4
/dev/zram1  zstd          375M 230.4M   7.2M  8.2M       4
/dev/zram0  lzo-rle       500M    12K   1.6K   40K       4
/dev/zram15 zstd          500M  30.4M   3.2M  3.6M       4
/dev/zram14 zstd          500M 161.2M  33.2M 34.8M       4
/dev/zram13 zstd          500M  22.9M   1.8M  2.2M       4
/dev/zram12 zstd          500M  17.7M 999.6K  1.3M       4
/dev/zram11 zstd          500M 171.4M  27.5M 28.7M       4
/dev/zram10 zstd          500M 166.1M  26.5M 27.6M       4
/dev/zram9  zstd          500M  75.7M  10.9M 11.5M       4
/dev/zram8  zstd          500M 265.7M  46.7M 48.3M       4
/dev/zram7  zstd          500M    19M   1.1M  1.4M       4
/dev/zram6  zstd          500M 236.6M  38.7M 40.2M       4
/dev/zram5  zstd          500M 227.3M    37M 38.4M       4
/dev/zram4  zstd          500M 474.4M  79.7M 82.2M       4 /opt/zram/zram4
/dev/zram3  zstd          500M 476.8M  86.8M 89.3M       4
/dev/zram2  zstd          500M 474.6M  80.3M 82.7M       4 /opt/zram/zram2
Can I fix openhab somehow?
