Frequent InfluxDB errors: "The error occurred during writing of data"
  • Platform information:
    • Hardware: CPUArchitecture/RAM/storage
    • OS: CoreOS → Docker
  • runtimeInfo:
    version: 4.0.3
    buildString: Release Build
    locale: de-DE
    systemInfo:
    configFolder: /openhab/conf
    userdataFolder: /openhab/userdata
    logFolder: /openhab/userdata/logs
    javaVersion: 17.0.8
    javaVendor: Alpine
    osName: Linux
    osVersion: 6.4.15-200.fc38.x86_64
    osArchitecture: amd64
    availableProcessors: 2
    freeMemory: 433257616
    totalMemory: 868220928
    startLevel: 70
    addons:
I frequently get these huge error messages in frontail, that something during writing of data into influxdb did not work
Im using InfluxDB 2 for persistence and (i think) its working fine
Both, openhab and influxdb are running on the same machine as docker container
Should i even care about these errors?
2023-10-03 17:42:02.369 [ERROR] [.client.write.events.WriteErrorEvent] - The error occurred during writing of data
com.influxdb.exceptions.InfluxException: interrupted
	at com.influxdb.client.internal.AbstractWriteClient.toInfluxException(AbstractWriteClient.java:546) ~[?:?]
	at com.influxdb.client.internal.AbstractWriteClient.lambda$new$12(AbstractWriteClient.java:178) ~[?:?]
	at io.reactivex.internal.subscribers.LambdaSubscriber.onNext(LambdaSubscriber.java:65) ~[?:?]
	at io.reactivex.internal.operators.flowable.FlowableDoFinally$DoFinallySubscriber.onNext(FlowableDoFinally.java:84) ~[?:?]
	at io.reactivex.internal.operators.mixed.FlowableConcatMapMaybe$ConcatMapMaybeSubscriber.drain(FlowableConcatMapMaybe.java:284) ~[?:?]
	at io.reactivex.internal.operators.mixed.FlowableConcatMapMaybe$ConcatMapMaybeSubscriber.innerSuccess(FlowableConcatMapMaybe.java:179) ~[?:?]
	at io.reactivex.internal.operators.mixed.FlowableConcatMapMaybe$ConcatMapMaybeSubscriber$ConcatMapMaybeObserver.onSuccess(FlowableConcatMapMaybe.java:322) ~[?:?]
	at io.reactivex.internal.operators.maybe.MaybeOnErrorNext$OnErrorNextMaybeObserver.onSuccess(MaybeOnErrorNext.java:88) ~[?:?]
	at io.reactivex.internal.operators.maybe.MaybePeek$MaybePeekObserver.onSuccess(MaybePeek.java:122) ~[?:?]
	at io.reactivex.internal.operators.maybe.MaybeMap$MapMaybeObserver.onSuccess(MaybeMap.java:89) ~[?:?]
	at io.reactivex.internal.operators.flowable.FlowableSingleMaybe$SingleElementSubscriber.onComplete(FlowableSingleMaybe.java:104) ~[?:?]
	at io.reactivex.subscribers.SerializedSubscriber.onComplete(SerializedSubscriber.java:168) ~[?:?]
	at io.reactivex.internal.operators.flowable.FlowableRetryWhen$RetryWhenSubscriber.onComplete(FlowableRetryWhen.java:82) ~[?:?]
	at io.reactivex.internal.subscriptions.DeferredScalarSubscription.complete(DeferredScalarSubscription.java:134) ~[?:?]
	at io.reactivex.internal.operators.maybe.MaybeToFlowable$MaybeToFlowableSubscriber.onSuccess(MaybeToFlowable.java:70) ~[?:?]
	at io.reactivex.internal.operators.maybe.MaybeFromCallable.subscribeActual(MaybeFromCallable.java:61) ~[?:?]
	at io.reactivex.Maybe.subscribe(Maybe.java:4290) ~[?:?]
	at io.reactivex.internal.operators.maybe.MaybeMap.subscribeActual(MaybeMap.java:40) ~[?:?]
	at io.reactivex.internal.operators.maybe.MaybeToFlowable.subscribeActual(MaybeToFlowable.java:45) ~[?:?]
	at io.reactivex.Flowable.subscribe(Flowable.java:14935) ~[?:?]
	at io.reactivex.Flowable.subscribe(Flowable.java:14882) ~[?:?]
	at io.reactivex.internal.operators.flowable.FlowableRepeatWhen$WhenReceiver.onNext(FlowableRepeatWhen.java:100) ~[?:?]
	at io.reactivex.internal.operators.flowable.FlowableFlatMap$MergeSubscriber.tryEmit(FlowableFlatMap.java:282) ~[?:?]
	at io.reactivex.internal.operators.flowable.FlowableFlatMap$InnerSubscriber.onNext(FlowableFlatMap.java:668) ~[?:?]
	at io.reactivex.subscribers.SerializedSubscriber.onNext(SerializedSubscriber.java:100) ~[?:?]
	at io.reactivex.internal.operators.flowable.FlowableDelay$DelaySubscriber$OnNext.run(FlowableDelay.java:114) ~[?:?]
	at io.reactivex.internal.schedulers.ScheduledRunnable.run(ScheduledRunnable.java:66) ~[?:?]
	at io.reactivex.internal.schedulers.ScheduledRunnable.call(ScheduledRunnable.java:57) ~[?:?]
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1136) ~[?:?]
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:635) ~[?:?]
	at java.lang.Thread.run(Thread.java:833) ~[?:?]
Caused by: java.io.InterruptedIOException: interrupted
	at okio.Timeout.throwIfReached(Timeout.java:146) ~[?:?]
	at okio.Okio$1.write(Okio.java:76) ~[?:?]
	at okio.AsyncTimeout$1.write(AsyncTimeout.java:180) ~[?:?]
	at okio.RealBufferedSink.flush(RealBufferedSink.java:224) ~[?:?]
	at okhttp3.internal.http1.Http1ExchangeCodec.finishRequest(Http1ExchangeCodec.java:190) ~[?:?]
	at okhttp3.internal.connection.Exchange.finishRequest(Exchange.java:101) ~[?:?]
	at okhttp3.internal.http.CallServerInterceptor.intercept(CallServerInterceptor.java:86) ~[?:?]
	at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:142) ~[?:?]
	at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.java:43) ~[?:?]
	at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:117) ~[?:?]
	at okhttp3.internal.cache.CacheInterceptor.intercept(CacheInterceptor.java:94) ~[?:?]
	at okhttp3.internal.http.BridgeInterceptor.intercept(BridgeInterceptor.java:93) ~[?:?]
	at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.java:88) ~[?:?]
	at com.influxdb.client.internal.GzipInterceptor.intercept(GzipInterceptor.java:91) ~[?:?]
	at com.influxdb.client.internal.AuthenticateInterceptor.intercept(AuthenticateInterceptor.java:97) ~[?:?]
	at okhttp3.logging.HttpLoggingInterceptor.intercept(HttpLoggingInterceptor.java:152) ~[?:?]
	at com.influxdb.internal.UserAgentInterceptor.intercept(UserAgentInterceptor.java:60) ~[?:?]
	at okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.java:229) ~[?:?]
	at okhttp3.RealCall.execute(RealCall.java:81) ~[?:?]
	at retrofit2.OkHttpCall.execute(OkHttpCall.java:188) ~[?:?]
	at io.reactivex.internal.operators.maybe.MaybeMap$MapMaybeObserver.onSuccess(MaybeMap.java:82) ~[?:?]
	at io.reactivex.internal.operators.flowable.FlowableRetryWhen.subscribeActual(FlowableRetryWhen.java:62) ~[?:?]
	at io.reactivex.internal.operators.flowable.FlowableSingleMaybe.subscribeActual(FlowableSingleMaybe.java:34) ~[?:?]
	at io.reactivex.internal.operators.maybe.MaybePeek.subscribeActual(MaybePeek.java:56) ~[?:?]
	at io.reactivex.internal.operators.maybe.MaybeOnErrorNext.subscribeActual(MaybeOnErrorNext.java:46) ~[?:?]
	at io.reactivex.internal.operators.mixed.FlowableConcatMapMaybe$ConcatMapMaybeSubscriber.drain(FlowableConcatMapMaybe.java:276) ~[?:?]
	... 33 more
Probably. That means that you are losing data entry points.
What’s the system load on the machine? File system isn’t full?
Uh so easy,
some of my services led to high performance peaks and i think its exactly what you are guessing → These errors occur when my homeserver has a very high load
Thanks for your time
