Hello.
I have had my zwave network up for a week now, and an noticing quite a lot of Timeout while sending message errors.
In most cases, retransmissions don’t succeed either.
My .items file contains:
Group kitchen
Group livingRoom
Group switches
Group lights
Group sensors
Group remotes
Group div
Group phones
Dimmer WallplugStuaCornerLamp "Lampe (sofa)" <dimmablelight> (livingRoom, lights) { channel = "zwave:device:3f5c8071:node13:switch_dimmer" }
Dimmer WallplugStuaShelfLamp "Lampett (hylle)" <dimmablelight> (livingRoom, lights) { channel = "zwave:device:3f5c8071:node10:switch_dimmer" }
Dimmer WallplugStuaWooferLamp "Lampett (woofer)" <dimmablelight> (livingRoom, lights) { channel = "zwave:device:3f5c8071:node8:switch_dimmer" }
Dimmer WallplugStuaPianoLamp "Pianolampe" <dimmablelight> (livingRoom, lights) { channel = "zwave:device:3f5c8071:node9:switch_dimmer" }
Dimmer BuildInStuaWindowLamps "Karnapp" <dimmablelight> (livingRoom, lights) { channel = "zwave:device:3f5c8071:node19:switch_dimmer" }
Dimmer BuildInKjDiningTableLamp "Pendel (spisebord)" <dimmablelight> (livingRoom, lights) { channel = "zwave:device:3f5c8071:node18:switch_dimmer" }
Dimmer WallplugKjCornerLamp "Lampe (spisestue)" <dimmablelight> (livingRoom, lights) { channel = "zwave:device:3f5c8071:node14:switch_dimmer" }
Dimmer BuildInKjRoofBenchLamp "Tak (kjøkkenbenk)" <dimmablelight> (kitchen, lights) { channel = "zwave:device:3f5c8071:node16:switch_dimmer" }
Dimmer BuildInKjRoofIslandLamp "Tak (kjøkkenøy)" <dimmablelight> (kitchen, lights) { channel = "zwave:device:3f5c8071:node17:switch_dimmer" }
Switch WallplugKjokkenPCBenchLamp "Benk (PCer)" <light> (kitchen, lights) { channel = "zwave:device:3f5c8071:node3:switch_binary" }
Switch BuildInKjokkenBench "Benk (overskap)" <light> (kitchen, lights) { channel = "zwave:device:3f5c8071:node15:switch_binary" }
Number LivingRoomTemperature "Temperatur (stue)" <temperature> (div, sensors) { channel = "zwave:device:3f5c8071:node7:sensor_temperature" }
Switch WallplugHeaterLexus "Motorvarmer Lexus" <poweroutlet> (div, switches) { channel = "zwave:device:3f5c8071:node12:switch_binary" }
Switch WallplugReceiver "Receiver (loft)" <receiver> (div, switches) { channel = "zwave:device:3f5c8071:node11:switch_binary" }
Switch WallplugTV "TV" <television> (div, switches) { channel = "zwave:device:3f5c8071:node4:switch_binary" }
Number WallSwitchStua "Bryter (stua)" <wallswitch> (div, remotes) { channel = "zwave:device:3f5c8071:node22:scene_number" }
Number WallSwitchKjokken "Bryter (kjøkken)" <wallswitch> (div, remotes) { channel = "zwave:device:3f5c8071:node6:scene_number" }
Alle dimmers and switches are Nexa zwave, except for node12 which is a Fibaro Wall Plug.
Snippet of last hour log grep:
2017-03-05 14:01:07.585 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 4: Timeout while sending message. Requeueing - 2 attempts left!
2017-03-05 14:01:12.588 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 4: Timeout while sending message. Requeueing - 1 attempts left!
2017-03-05 14:01:17.591 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 4: Timeout while sending message. Requeueing - 0 attempts left!
2017-03-05 14:01:27.857 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 11: Timeout while sending message. Requeueing - 2 attempts left!
2017-03-05 14:01:32.861 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 11: Timeout while sending message. Requeueing - 1 attempts left!
2017-03-05 14:01:37.864 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 11: Timeout while sending message. Requeueing - 0 attempts left!
2017-03-05 14:01:48.045 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 10: Timeout while sending message. Requeueing - 2 attempts left!
2017-03-05 14:01:53.048 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 10: Timeout while sending message. Requeueing - 1 attempts left!
2017-03-05 14:01:58.051 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 10: Timeout while sending message. Requeueing - 0 attempts left!
2017-03-05 14:02:08.661 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 3: Timeout while sending message. Requeueing - 2 attempts left!
2017-03-05 14:02:13.725 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 3: Timeout while sending message. Requeueing - 2 attempts left!
2017-03-05 14:02:18.729 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 3: Timeout while sending message. Requeueing - 1 attempts left!
2017-03-05 14:02:23.732 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 3: Timeout while sending message. Requeueing - 0 attempts left!
2017-03-05 14:02:40.073 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 13: Timeout while sending message. Requeueing - 2 attempts left!
2017-03-05 14:02:45.076 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 13: Timeout while sending message. Requeueing - 1 attempts left!
2017-03-05 14:02:50.079 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 13: Timeout while sending message. Requeueing - 0 attempts left!
2017-03-05 14:06:49.411 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 12: Timeout while sending message. Requeueing - 2 attempts left!
2017-03-05 14:06:54.414 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 12: Timeout while sending message. Requeueing - 1 attempts left!
2017-03-05 14:06:59.417 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 12: Timeout while sending message. Requeueing - 0 attempts left!
2017-03-05 14:31:07.586 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 4: Timeout while sending message. Requeueing - 2 attempts left!
2017-03-05 14:31:12.590 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 4: Timeout while sending message. Requeueing - 1 attempts left!
2017-03-05 14:31:17.594 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 4: Timeout while sending message. Requeueing - 0 attempts left!
2017-03-05 14:31:27.864 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 11: Timeout while sending message. Requeueing - 2 attempts left!
2017-03-05 14:31:32.867 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 11: Timeout while sending message. Requeueing - 1 attempts left!
2017-03-05 14:31:37.871 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 11: Timeout while sending message. Requeueing - 0 attempts left!
2017-03-05 14:31:48.230 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 14: Timeout while sending message. Requeueing - 2 attempts left!
2017-03-05 14:31:53.234 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 14: Timeout while sending message. Requeueing - 1 attempts left!
2017-03-05 14:31:58.237 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 14: Timeout while sending message. Requeueing - 0 attempts left!
2017-03-05 14:32:08.635 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 9: Timeout while sending message. Requeueing - 2 attempts left!
2017-03-05 14:32:13.639 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 9: Timeout while sending message. Requeueing - 1 attempts left!
2017-03-05 14:32:18.644 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 9: Timeout while sending message. Requeueing - 0 attempts left!
2017-03-05 14:32:28.708 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 3: Timeout while sending message. Requeueing - 2 attempts left!
2017-03-05 14:32:33.711 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 3: Timeout while sending message. Requeueing - 1 attempts left!
2017-03-05 14:32:38.715 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 3: Timeout while sending message. Requeueing - 0 attempts left!
2017-03-05 14:32:49.147 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 13: Timeout while sending message. Requeueing - 2 attempts left!
2017-03-05 14:32:54.151 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 13: Timeout while sending message. Requeueing - 1 attempts left!
2017-03-05 14:32:59.154 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 13: Timeout while sending message. Requeueing - 0 attempts left!
2017-03-05 14:33:09.282 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 8: Timeout while sending message. Requeueing - 2 attempts left!
2017-03-05 14:33:14.285 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 8: Timeout while sending message. Requeueing - 1 attempts left!
2017-03-05 14:33:19.288 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 8: Timeout while sending message. Requeueing - 0 attempts left!
2017-03-05 14:36:49.421 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 12: Timeout while sending message. Requeueing - 2 attempts left!
2017-03-05 14:36:54.424 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 12: Timeout while sending message. Requeueing - 1 attempts left!
2017-03-05 14:36:59.428 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 12: Timeout while sending message. Requeueing - 0 attempts left!
Here are all my logs for easy grep’ing: MyLogs
The only practical implication of this, is that my wall-switch remote sometimes takes 5s to react.
Appreciate if any with more OH2 knowhow than me could give logs a look.
I’m on OH2 Stable 2.0.0
Cheers
