Since yesterday evening I see lots of warnings in my log. All start with
2022-01-15 13:13:19.267 [WARN ] [org.eclipse.jetty.server.HttpChannel] - /rest/persistence/items/Error:%20Unexpected%20%22]%22%20at%20character%2031
java.lang.IllegalArgumentException: Illegal character in path at index 75: http://192.168 …
I have no clue, where to look for the reason for this. At the time, when the entries first popped up, I did nothing specific to the openhab installation.
I have already cleared / deleted the cache and the tmp directory. That was the closed hint from @rlkoshak I could find here.
I am runing the package version from OH3.2 on a PI4 with Buster.
As I wrote before, there are a lot of error messages in one entry, truncated at a certain point with the hint, that there would be 45 more lines. These all look like:
at org.apache.cxf.transport.servlet.BaseUrlHelper.getBaseURL(BaseUrlHelper.java:47) ~[?:?]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:501) ~[?:?]
Would there be anything where I can look closer, to identity the root cause? Would it help to paste the complete entry?
Like @rlkoshak says, “something” is sending a broken REST request to openHAB. Cannot say what,most likely a GUI, perhaps a rule, or something else.
/rest/persistence/items/xxxx
would retrieve persistence data for a named Item xxxx.
Here it’s tried to use "Error:%20Unexpected%20..." as an Item name, and blown up because : is illegal character in Item names.
It looks like the mystery requester has run into it’s own problem (an unexpected ] at char 31 of something else, maybe?), and is sending us an error message instead of an Item name.
To work out the mystery requester, you’ll have to think about who/what would request persistence data via REST. I would guess some charting widget.
what is using REST inside OpenHAB? My current understanding is, that REST is used, when I want to access something within OpenHAB from the outside. That is currently not used here. Or are there internal processes working with REST? Ie.: when I want to achieve xxx, OH normally uses REST requests…
Thanks for the help, I think we can close it.After @rlkoshak last comment I played around with my brwoswer and had the suspicion, that it could be in connection with some widgets, I have integrated in the last couple of days. Having a closer look, I did find that in two of them I was referring to an item, which does not exist:
actionAnalyzerItems: =[props.item +"_Total"]
when looking at the code
“actionAnalyzerItems”: “\u003d[props.item +”_EnergyUsage"]"
that could match the “Unexpected%20%22]%22” from the log.
After I corrected the entry, the error messages did not occur again.
The bad news is, that I saved the “wrong” widget file (uicomponents_ui_widget.json) before the change and reinstalled it after the positive result. The error did not reoccur, even with the widget including the missing item
