Need urgent help for my installation of OH2. It crashes frequntly at least once per day. I have already checked the logs, but actually couldnt find anything spectacular. It doesnt look like a ram leak, because there is no error or warning in the logs. The only thing I could find are the following lines below in the deamon.log. I am quite frustrated because i couldnt relly find a solution for that issue. Maybe there is someone who can help.
Jan 25 18:47:43 openHABianPi Node-RED[362]: 25 Jan 18:47:43 - [warn] [openhab2-controller:Openhab] ERROR {"type":{"code":"ECONNREFUSED","errno":"ECONNREFUSED","syscall$
Jan 25 18:47:44 openHABianPi Node-RED[362]: 25 Jan 18:47:44 - [warn] [openhab2-controller:Openhab] ERROR {"type":{"code":"ECONNREFUSED","errno":"ECONNREFUSED","syscall$
Jan 25 18:47:45 openHABianPi Node-RED[362]: 25 Jan 18:47:45 - [warn] [openhab2-controller:Openhab] ERROR {"type":{"code":"ECONNREFUSED","errno":"ECONNREFUSED","syscall$
Jan 25 18:47:46 openHABianPi Node-RED[362]: 25 Jan 18:47:46 - [warn] [openhab2-controller:Openhab] ERROR {"type":{"code":"ECONNREFUSED","errno":"ECONNREFUSED","syscall$
Jan 25 18:47:47 openHABianPi Node-RED[362]: 25 Jan 18:47:47 - [warn] [openhab2-controller:Openhab] ERROR {"type":{"code":"ECONNREFUSED","errno":"ECONNREFUSED","syscall$
Jan 25 18:47:48 openHABianPi systemd[1]: openhab2.service: Service hold-off time over, scheduling restart.
Jan 25 18:47:48 openHABianPi systemd[1]: Stopped openHAB 2 - empowering the smart home.
Jan 25 18:47:48 openHABianPi systemd[1]: Started openHAB 2 - empowering the smart home.
Jan 25 18:18:25 openHABianPi dhcpcd[483]: eth0: soliciting an IPv6 router
Jan 25 18:18:25 openHABianPi dhcpcd[483]: eth0: probing address 192.168.XXX.XX
Jan 25 18:18:26 openHABianPi Node-RED[380]: 25 Jan 18:18:26 - [warn] [openhab2-controller:Openhab] ERROR {"type":"error","status":404}
Jan 25 18:18:31 openHABianPi dhcpcd[483]: eth0: leased 192.168.XXX.XX for 864000 seconds
Jan 25 18:18:31 openHABianPi avahi-daemon[375]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.XX.XX.
Jan 25 18:18:31 openHABianPi dhcpcd[483]: eth0: adding route to 192.168.XX.XX
Jan 25 18:18:31 openHABianPi avahi-daemon[375]: New relevant interface eth0.IPv4 for mDNS.
Jan 25 18:18:31 openHABianPi dhcpcd[483]: eth0: adding default route via 192.168.XX.XX
Jan 25 18:18:31 openHABianPi avahi-daemon[375]: Registering new address record for 192.168.XX.XX on eth0.IPv4.
Jan 25 18:18:33 openHABianPi Node-RED[380]: 25 Jan 18:18:33 - [warn] [openhab2-out:Aussentemperatur] response error '{"statusCode":503,"body":"","headers":{"connection$
