I just did a fresh install of the IDE with Eclipse on macOS using Eclipse 2022-03 The initial build doesn’t get through, it shows an X for the pom.xml
This started when I closed and re-opened the IDE, also a fresh install (twice) doesn’t help. Andy idea? @wborn ?
It works fine for me with a fresh Eclipse 2022-03 install.
Maybe it has some download issues for you? If something is wrong with your local Maven repo you could try to clean it… or do a command line Maven build and see if that does work or fix it.
yes, I cleaned the .m2 repo completely and reinstalled the IDE and now it works, thx
