Just found a solution for myself:
Had to configure the IP and network in /var/lib/openhab2/config/org/exclipe/smarthome/network.config by hand with a texteditor.
For me this is solved, but after or within a fresh installation, there must be a question oder an automatic configuration of Network there!
Also this behavior is very odd, I have setup up openHAB on Debian, Ubuntu, Arch, Docker and more.
I never experienced this behavior, I know the openHAB initial startup can take a while so there is no web-interface, but this can be seen in the logs.
What exactly is your setup? You just state 20.04 Lts
Is there anything special about this setup? 2 LAN Interfaces or something?
I have got three interfaces:
Vpn (tun0) with Class c subnet (10.10.2.x)
External lan to router (eth0) with class c subnet 192.168.1.x
Internal lan (eth1) with class b subnet 10.10.1.x)
I got error messages for all up Adressen given to this three devices and for local host 127.0.0.1
I searched in forum and found solution to set ip and network via paperUI, but paperUI not startable on this system.
So I searched on other system with openhab running and found entry
primaryAddress=“10.10.1.1/16”
In this file. So i added and openhab started.
If I look in documentation normally openhab should have been started for all ips, until this is set via paperUI
