this time i do a clean installation of openhabian on my sd card and then install openhab.
Now i am struggling with the following error:
Mar 30 12:32:35 openhabian systemd[1]: Starting openhab.service - openHAB - empowering the smart home...
Mar 30 12:32:35 openhabian systemd[1]: Started openhab.service - openHAB - empowering the smart home.
Mar 30 12:32:35 openhabian karaf[858]: mkdir: cannot create directory ‘/var/lib/openhab/tmp’: Permission denied
Mar 30 12:32:36 openhabian karaf[830]: KARAF_ETC is not valid: /var/lib/openhab/etc
Mar 30 12:32:36 openhabian systemd[1]: openhab.service: Main process exited, code=exited, status=1/FAILURE
Mar 30 12:32:36 openhabian systemd[1]: openhab.service: Failed with result 'exit-code'.
Mar 30 12:32:41 openhabian systemd[1]: openhab.service: Scheduled restart job, restart counter is at 1.
Mar 30 12:32:41 openhabian systemd[1]: Stopped openhab.service - openHAB - empowering the smart home.
Mar 30 12:32:41 openhabian systemd[1]: Starting openhab.service - openHAB - empowering the smart home...
Mar 30 12:32:41 openhabian systemd[1]: Started openhab.service - openHAB - empowering the smart home.
how can i fix it so that my openhab will start?
now i got this error:
Mar 30 13:00:05 openhabian systemd[1]: openhab.service: Failed with result 'exit-code'.
Mar 30 13:00:05 openhabian systemd[1]: Stopped openhab.service - openHAB - empowering the smart home.
Mar 30 13:00:05 openhabian systemd[1]: openhab.service: Consumed 9.689s CPU time.
Mar 30 13:00:05 openhabian systemd[1]: Starting openhab.service - openHAB - empowering the smart home...
Mar 30 13:00:05 openhabian systemd[1]: Started openhab.service - openHAB - empowering the smart home.
Mar 30 13:00:06 openhabian karaf[30203]: WARN: can't update etc/config.properties with the generated command shutdown. We advise to manually add the karaf.shutdown.command property.
Mar 30 13:00:07 openhabian karaf[30203]: java.io.FileNotFoundException: /var/lib/openhab/tmp/karaf.pid (Permission denied)
Mar 30 13:00:07 openhabian karaf[30203]: at java.base/java.io.FileOutputStream.open0(Native Method)
Mar 30 13:00:07 openhabian karaf[30203]: at java.base/java.io.FileOutputStream.open(FileOutputStream.java:293)
Mar 30 13:00:07 openhabian karaf[30203]: at java.base/java.io.FileOutputStream.<init>(FileOutputStream.java:235)
Mar 30 13:00:07 openhabian karaf[30203]: at java.base/java.io.FileOutputStream.<init>(FileOutputStream.java:123)
Mar 30 13:00:07 openhabian karaf[30203]: at org.apache.karaf.main.InstanceHelper.writePid(InstanceHelper.java:126)
Mar 30 13:00:07 openhabian karaf[30203]: at org.apache.karaf.main.Main.launch(Main.java:278)
Mar 30 13:00:07 openhabian karaf[30203]: at org.apache.karaf.main.Main.main(Main.java:183)
Mar 30 13:00:08 openhabian karaf[30203]: java.lang.RuntimeException: Exception instantiating lock class org.apache.karaf.main.lock.SimpleFileLock
Mar 30 13:00:08 openhabian karaf[30203]: Karaf can't startup, make sure the log file can be accessed and written by the user starting Karaf : /var/lib/openhab/tmp/lock (Permission denied)
Mar 30 13:00:08 openhabian karaf[30203]: at org.apache.karaf.main.Main.createLock(Main.java:556)
Mar 30 13:00:08 openhabian karaf[30203]: at org.apache.karaf.main.Main.doMonitor(Main.java:420)
Mar 30 13:00:08 openhabian karaf[30203]: at org.apache.karaf.main.Main.access$100(Main.java:78)
Mar 30 13:00:08 openhabian karaf[30203]: at org.apache.karaf.main.Main$3.run(Main.java:409)
Mar 30 13:00:08 openhabian karaf[30203]: Caused by: java.lang.reflect.InvocationTargetException
Mar 30 13:00:08 openhabian karaf[30203]: at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
Mar 30 13:00:08 openhabian karaf[30203]: at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:77)
Mar 30 13:00:08 openhabian karaf[30203]: at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
Mar 30 13:00:08 openhabian karaf[30203]: at java.base/java.lang.reflect.Constructor.newInstanceWithCaller(Constructor.java:499)
Mar 30 13:00:08 openhabian karaf[30203]: at java.base/java.lang.reflect.Constructor.newInstance(Constructor.java:480)
Mar 30 13:00:08 openhabian karaf[30203]: at org.apache.karaf.main.Main.createLock(Main.java:552)
Mar 30 13:00:08 openhabian karaf[30203]: ... 3 more
Mar 30 13:00:08 openhabian karaf[30203]: Caused by: java.lang.RuntimeException: Karaf can't startup, make sure the log file can be accessed and written by the user starting Karaf : /var/lib/openh>
Mar 30 13:00:08 openhabian karaf[30203]: at org.apache.karaf.main.lock.SimpleFileLock.<init>(SimpleFileLock.java:55)
Mar 30 13:00:08 openhabian karaf[30203]: ... 9 more
Mar 30 13:00:08 openhabian karaf[30203]: Caused by: java.io.FileNotFoundException: /var/lib/openhab/tmp/lock (Permission denied)
Mar 30 13:00:08 openhabian karaf[30203]: at java.base/java.io.RandomAccessFile.open0(Native Method)
Mar 30 13:00:08 openhabian karaf[30203]: at java.base/java.io.RandomAccessFile.open(RandomAccessFile.java:344)
Mar 30 13:00:08 openhabian karaf[30203]: at java.base/java.io.RandomAccessFile.<init>(RandomAccessFile.java:259)
Mar 30 13:00:08 openhabian karaf[30203]: at java.base/java.io.RandomAccessFile.<init>(RandomAccessFile.java:213)
Mar 30 13:00:08 openhabian karaf[30203]: at org.apache.karaf.main.lock.SimpleFileLock.<init>(SimpleFileLock.java:53)
EDIT: after klick “Fix permission” in openhabian my openhab is now booting
