Fritz.Box Binding fails when executing switch, scan or simliar
I was able to great a proper configuration which shows bridge and a fritz dect 200 plug are online.
When I execute the switch on my sitemap the following error appears in log and the thing etc. show status offline. If I open the thing and store same configuration, things show green online status.
19:13:22.679 [ERROR] [rnal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.handleCommand()' on 'org.openhab.binding.avmfritz.internal.handler.DeviceHandler@1b17ed7': Illegal character in query at index 89: http://192.168.178.1:1012/webservices/homeautoswitch.lua?switchcmd=setswitchoff&ain=11630 0068564
java.lang.IllegalArgumentException: Illegal character in query at index 89: http://192.168.178.1:1012/webservices/homeautoswitch.lua?switchcmd=setswitchoff&ain=11630 0068564
My setup:
Raspberry Pi 3 Model B Rev 1.2
Linux raspberrypi 5.15.84-v8+ #1613 SMP PREEMPT Thu Jan 5 12:03:08 GMT 2023 aarch64 GNU/Linux
total used free gemns. Puffer/Cache verfügbar
memory: 931460 591772 23940 7908 315748 356936
Swap: 3764220 222624 3541596
openjdk version “11.0.18” 2023-01-17 LTS
OpenJDK Runtime Environment Zulu11.62+17-CA (build 11.0.18+10-LTS)
OpenJDK Client VM Zulu11.62+17-CA (build 11.0.18+10-LTS, mixed mode)
Config:property-list
automation = pidcontroller
binding = onewire,ntp,smartmeter,shelly,avmfritz
misc = metrics
package = standard
persistence = influxdb
transformation = jsonpath
ui = basic,habpanel
