At the moment I am trying to migrate my Raspberry3 Setup to my new MacMini-Server.
I have some trouble doing this and one of the points that are unclear to me is that the TR064 Fritz Box Binding is not working at all.
When I launch OH2 via Terminal I get this errors in the Karaf-console after a few minutes:
openhab> java.lang.NullPointerException
at org.openhab.binding.fritzboxtr064.internal.Tr064Comm.soapToString(Tr064Comm.java:429)
at org.openhab.binding.fritzboxtr064.internal.Tr064Comm.getTr064Values(Tr064Comm.java:249)
at org.openhab.binding.fritzboxtr064.internal.FritzboxTr064Binding.execute(FritzboxTr064Binding.java:211)
at org.openhab.core.binding.AbstractActiveBinding$BindingActiveService.execute(AbstractActiveBinding.java:144)
at org.openhab.core.service.AbstractActiveService$RefreshThread.run(AbstractActiveService.java:166)
I did not make any changes at all to my .cfg, .things and .items files so I am pretty sure, everything is set up correctly.
I installed the java alternative Zulu as recommended in the introduction Readme. That and the OS change from Unix to OS X are the only changes I made …
My OH Log:
schemas.xmlsoap.org/soap/encoding/">
2018-05-26 21:24:16.405 [ERROR] [ing.fritzboxtr064.internal.Tr064Comm] - Could not read response from FritzBox. Unauthorized! Check User/PW in config. Create user for tr064 requests
2018-05-26 21:24:16.407 [WARN ] [ing.fritzboxtr064.internal.Tr064Comm] - Error retrieving SOAP response from FritzBox
I double checked username and password and even tried switching from https to http but it did not have any effect.
I just can’t get it to work.
I implemented the Binding using the addons.cfg. I deleted it from there and reinstalled it manually.
Created a new user at the FB and even tried with admin (Http and https). It just won’t find my fritz box …
openhab finds your fritzbox and is able to connect with https, so no need for http.
But there is a problem with the authentication (which has nothing to do with https).
If the password/user combination is correct as you’ve written, there are two other scenarios possible:
Did you configure the fritz box to allow access by an application account? There is a setting for this:
Click “Home Network” in the FRITZ!Box user interface.
Click “Home Network Overview” in the “Home Network” menu.
Click on the “Network Settings” tab.
Enable the option “Allow access for applications” in the “Access Settings in the Home Network” section. If the section is not displayed, enable the Advanced View first.
Click “Apply” to save the settings.
→ From Fritzbox Knowledge Base
Access for applications is allowed and i created an openhab user that has access too.
I just can’t get it to work. I even tried with my admin and admin-pw but the only thing i get from the log is:
2018-06-18 09:28:42.238 [INFO ] [b.core.service.AbstractActiveService] - FritzboxTr064 Refresh Service has been started
2018-06-18 09:29:19.038 [INFO ] [b.core.service.AbstractActiveService] - FritzboxTr064 Refresh Service has been shut down
It worked on my raspberry but now i can’t get it to work.
I also installed the AVMFritz binding for my DECT Switches and this is working perfectly.
I will take a look at the link to github you provieded.
I have exactly the same problem. I tried everything for hours. First i thought it might be a problem with fritzbox certificate, so i signed in at myfritz.net to get a new certificate by activating Let´s enrypt. It didn´t work either.
Did you fix the Problem in the meantime? Has anybody an idea what i´m doing wrong?
This is an info point
I recognized, that it’s working anyway. I expected a thing to be created in Paper UI but that’s not the case. It’s working anyway though. Please check, if you can turn on/off your wifi with the items you created It’s working great for me!
Hi Jonas!
Thanks so much. It works! I can turn on/off the wifi and the presence item work aswell. Unfortunately all informations that have to do with dsl are not shown. But I think this has something to do with the cable-Fritbox…
It’s me again.
I do have some problems with the binding for some time now and cannot find a way to fix it.
The Log plots this every few minutes:
2020-04-04 22:35:26.791 [WARN ] [itzboxtr064.internal.SoapValueParser] - Fault received from FritzBox for item wifi24Switch in SOAP response <?xml version="1.0"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
