Hello, everyone,
Unfortunately, I can’t get my “Fritz Bridge” to run.
I think I saw that it worked shortly after installing it.
Now the “Fritzbox” is unfortunately “UNKNOWN”
I think I did everything right, but unfortunately I have to realize that this can’t be.
Please next time do not post a screenshot but copy the log or other code and use paste it into a code block, as it is much more easier for others to read it.
Log goes here
There is no log message at all related to the avm binding.
Have you captured the log at the time when you have configured the thing? Maybe disabled / enable your thing again and look at the log, otherwise review your log settings, e.g. via karaf console
openhabian@openhabian:~ $ grep -i 'fritz' /var/log/openhab/events.log
2022-09-25 01:23:23.693 [INFO ] [openhab.event.InboxAddedEvent ] - Discovery Result with UID 'avmfritz:fritzbox:192_168_178_1' has been added.
2022-09-25 01:23:23.715 [INFO ] [openhab.event.InboxAddedEvent ] - Discovery Result with UID 'avmfritz:fritzbox:192_168_178_111' has been added.
2022-09-25 01:35:48.092 [INFO ] [openhab.event.InboxRemovedEvent ] - Discovery Result with UID 'avmfritz:fritzbox:192_168_178_1' has been removed.
2022-09-25 01:35:48.194 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'avmfritz:fritzbox:192_168_178_1' changed from UNINITIALIZED to INITIALIZING
2022-09-25 01:35:48.229 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'avmfritz:fritzbox:192_168_178_1' changed from INITIALIZING to UNKNOWN
2022-09-25 01:35:48.237 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'avmfritz:fritzbox:192_168_178_1' changed from UNKNOWN to OFFLINE (CONFIGURATION_ERROR): The 'password' parameter must be configured to use the AHA features.
2022-09-25 01:35:57.446 [INFO ] [openhab.event.InboxRemovedEvent ] - Discovery Result with UID 'avmfritz:fritzbox:192_168_178_111' has been removed.
2022-09-25 01:35:57.512 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'avmfritz:fritzbox:192_168_178_111' changed from UNINITIALIZED to INITIALIZING
2022-09-25 01:35:57.548 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'avmfritz:fritzbox:192_168_178_111' changed from INITIALIZING to UNKNOWN
2022-09-25 01:35:57.555 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'avmfritz:fritzbox:192_168_178_111' changed from UNKNOWN to OFFLINE (CONFIGURATION_ERROR): The 'password' parameter must be configured to use the AHA features.
2022-09-25 10:27:02.213 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'avmfritz:fritzbox:192_168_178_1' changed from OFFLINE (CONFIGURATION_ERROR): The 'password' parameter must be configured to use the AHA features. to UNKNOWN
2022-09-25 10:27:04.238 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'avmfritz:fritzbox:192_168_178_1' changed from UNKNOWN to OFFLINE (COMMUNICATION_ERROR): FRITZ!Box does not respond.
2022-09-25 10:27:06.369 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'avmfritz:fritzbox:192_168_178_1' changed from OFFLINE (COMMUNICATION_ERROR): FRITZ!Box does not respond. to ONLINE
2022-09-25 10:27:55.552 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'avmfritz:fritzbox:192_168_178_111' changed from OFFLINE (CONFIGURATION_ERROR): The 'password' parameter must be configured to use the AHA features. to UNKNOWN
2022-09-25 10:27:56.671 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'avmfritz:fritzbox:192_168_178_111' changed from UNKNOWN to ONLINE
2022-09-25 20:45:48.412 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'avmfritz:fritzbox:192_168_178_1' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): FRITZ!Box does not respond.
2022-09-25 20:45:48.421 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'avmfritz:fritzbox:192_168_178_1' changed from OFFLINE (COMMUNICATION_ERROR): FRITZ!Box does not respond. to OFFLINE (COMMUNICATION_ERROR): Request is invalid
2022-09-25 20:45:51.413 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'avmfritz:fritzbox:192_168_178_111' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): FRITZ!Box does not respond.
2022-09-25 20:45:53.419 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'avmfritz:fritzbox:192_168_178_111' changed from OFFLINE (COMMUNICATION_ERROR): FRITZ!Box does not respond. to OFFLINE (COMMUNICATION_ERROR): Request is invalid
2022-09-25 20:45:59.909 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'avmfritz:fritzbox:192_168_178_1' changed from OFFLINE (COMMUNICATION_ERROR): Request is invalid to OFFLINE (COMMUNICATION_ERROR): FRITZ!Box does not respond.
2022-09-25 20:46:01.919 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'avmfritz:fritzbox:192_168_178_1' changed from OFFLINE (COMMUNICATION_ERROR): FRITZ!Box does not respond. to OFFLINE (COMMUNICATION_ERROR): Request is invalid
2022-09-25 20:46:08.406 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'avmfritz:fritzbox:192_168_178_111' changed from OFFLINE (COMMUNICATION_ERROR): Request is invalid to OFFLINE (COMMUNICATION_ERROR): FRITZ!Box does not respond.
2022-09-25 20:46:16.911 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'avmfritz:fritzbox:192_168_178_1' changed from OFFLINE (COMMUNICATION_ERROR): Request is invalid to OFFLINE (COMMUNICATION_ERROR): FRITZ!Box does not respond.
2022-09-25 20:47:52.981 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'avmfritz:fritzbox:192_168_178_111' changed from OFFLINE (COMMUNICATION_ERROR): FRITZ!Box does not respond. to UNKNOWN
2022-09-26 22:44:24.508 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'avmfritz:fritzbox:192_168_178_1' changed from OFFLINE (COMMUNICATION_ERROR): FRITZ!Box does not respond. to UNKNOWN
openhabian@openhabian:~ $ grep -i 'fritz' /var/log/openhab/openhab.log
2022-09-25 01:23:23.690 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'avmfritz:fritzbox:192_168_178_1' to inbox.
2022-09-25 01:23:23.708 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'avmfritz:fritzbox:192_168_178_111' to inbox.
