Thank you.
I found this behavior in my log files too.
On searching the Issues in the github project I did not find this issue.
I will try the SNAPSHOT version and change my item config as soon as I am home.
To make sure you understand me correctly. The issue isn’t solved yet. The snapshot version won’t work either. You have to install the fixed binding version manually by following my advice inside the linked issue.
