Hi, i use the Fritzbox-Binding to show calls on my webinterface.
Now i want to see my calls from the doorphone (ip doorphone) also, but i can only see external calls. Internal calls will not be shown.
Is there a way to enable this? My ip-doorphone is connected to my fritzbox as ip-phone. If someone rings the doorbell, i get internal calls to my phones around the house (group call **9).
Not sure whether you are still struggling with this, but as I had the same problem I thought to reply.
Apparently this is not possible because Fritz!OS does not show internal calls in the Call Monitor (for whatever reason). The solution I finally found is to register at an VoIP provider (sipcall) and have the doorbell calling an external number. In the sipcall config I then re-route calls from the doorbell back to the internal number. A bit cumbersome but it works and doesn’t generate any cost.
