Since I’m using fritz Mesh a reliable presence detection with the tr064 binding seems impossible. When a device disconnects from Wifi when it were connected to a repeater in the mesh the devices stays in the device list for round about 10 minutes and the tr064 binding detects it as online.
I have looked around for alternatives and found the fritzbox eventlog which is pretty verbose and accurate. It logs each connect and disconnect with the datetime, device, ip, MAC.
I was also able to find a shell script which automates the query process.
I’m wondering if there is already a solution that uses this eventlog.
