I have the same effect after a reboot of my OH-System (OH2.5.5) Every two hours there is a “Lost connection to Fritzbox because of interrupt”. Before the reboot this was not the case.
Is there a possibility to change this interval of 2h ?
[2020-06-14 04:00:00.007 [INFO ] [xtr064.internal.FritzboxTr064Binding] - Fritzbox Reconnect Job executed
2020-06-14 04:00:00.007 [INFO ] [g.fritzboxtr064.internal.CallMonitor] - Lost connection to Fritzbox because of interrupt
2020-06-14 04:00:05.011 [INFO ] [g.fritzboxtr064.internal.CallMonitor] - Connected to FritzBox on 192.168.178.1:1012
2020-06-14 06:00:00.001 [INFO ] [xtr064.internal.FritzboxTr064Binding] - Fritzbox Reconnect Job executed
2020-06-14 06:00:00.002 [INFO ] [g.fritzboxtr064.internal.CallMonitor] - Lost connection to Fritzbox because of interrupt
2020-06-14 06:00:05.005 [INFO ] [g.fritzboxtr064.internal.CallMonitor] - Connected to FritzBox on 192.168.178.1:1012
2020-06-14 08:00:00.001 [INFO ] [xtr064.internal.FritzboxTr064Binding] - Fritzbox Reconnect Job executed
2020-06-14 08:00:00.006 [INFO ] [g.fritzboxtr064.internal.CallMonitor] - Lost connection to Fritzbox because of interrupt
2020-06-14 08:00:05.002 [INFO ] [g.fritzboxtr064.internal.CallMonitor] - Connected to FritzBox on 192.168.178.1:1012
2020-06-14 10:00:00.001 [INFO ] [xtr064.internal.FritzboxTr064Binding] - Fritzbox Reconnect Job executed
2020-06-14 10:00:00.002 [INFO ] [g.fritzboxtr064.internal.CallMonitor] - Lost connection to Fritzbox because of interrupt
2020-06-14 10:00:05.005 [INFO ] [g.fritzboxtr064.internal.CallMonitor] - Connected to FritzBox on 192.168.178.1:1012
2020-06-14 12:00:00.002 [INFO ] [xtr064.internal.FritzboxTr064Binding] - Fritzbox Reconnect Job executed
2020-06-14 12:00:00.002 [INFO ] [g.fritzboxtr064.internal.CallMonitor] - Lost connection to Fritzbox because of interrupt
2020-06-14 12:00:05.007 [INFO ] [g.fritzboxtr064.internal.CallMonitor] - Connected to FritzBox on 192.168.178.1:1012]
If you know how to code in Java, you could possibly build an updated jar that changes the 2-hour period, but this is an OH1 binding that’s going to die off soon anyway.
