I would like to be able to detect presence of clients in my Guest Network, so the House will greet friends
Network health will obviously not work, so I thought maybe this binding could do the trick. Could someone with this binding working confirm or deny if this is possible?
Many thanks in advance,
Regards,
-OLI
It is not possible as far as I know: instead of known ip adresses (network health binding) you need to provide known mac addresses for presence detection with the tr064 binding.
Well I do know the mac adresses - the Admin GUI for fritzbox does show them for clients in the Guest LAN.
So the question remains if you can query them via the bindingā¦
I checked that in advance and hoped for a yes/no answer as the wiki doesnāt clearly state if it reports both āinternalā and guest network . I admit Iām a lazy fellow and wanted to avoid doing the work and finding out it doesnāt work afterwardsā¦
If it was only thatā¦install binding, configure router, set up items - for a 50 % chance itāll work. And Iām such a lazy bā¦eing
On the other handā¦the long nights are coming so if nobody else will chip in with a yay or nay Iāll just give it a try. Iāll report back then - whenever that may be
Better late then never. As promised I report back that yes indeed using the FritzboxTR064 Binding you can detect presence on your guest WiFi.
This will freak my guests out if the house greets them with āHello Name. It has been soandsomany days since you have visited meā
