Hi, I use the Fritzbox TR064 binding e.g. for monitoring network devices and presence-detection of smartphones. This worked fine with FritzOS 7.12, but (exactly) since FritzOS 7.20 release, I get frequent alerts from Openhab that some WIFI devices are offline (which they are not at that time). This happens up to 10-40 times a day.
The problem is not the binding, but the Fritzbox. I have run tests using FritzConnection with the same results.
I am wondering if anyone is experiencing the same issue?
This would help with getting the issue escalated with AVM support, who does not see the problem/priority yet (even after lengthy emails and exchange of log files) ;-).
I had the same issue since 7.20 was released. The only thing I changed was the activation of WPA3. A couple of days ago I switched back to WPA2 only and since then my phones online status has been reliable.
Using FritzOS 7.21 with tr064 and also discovering on and off especially of the mobile phones. I am still using WPA2 (CCMP) only. Can not say, since when it is this way.
I only recognized this because I looked into the logs because of this post. My presence detection works on a combination of tr064-, network-binding and re-checking after one and after a second minute. This is very stable and i can not remeber any false detections.
With my devices I basically do the same. If tr064- or network-binding detects a device offline I wait a minute and check if both bindings have the device offline, then i do whatever to solve the problem.
