Hey guys,
I would like to use my FritzBox 6590 Cable with FritzOS 7.0 to get presence detection.
But somehow the addon is not working for me.
I configured a user “openhab” and entered the ip and user/password in the binding config but the fritzbox thing doesnt show up in the inbox. Same if I click on “Search for Things” and on the Binding - nothing happens.
If I try to reinstall the binding hundreds of errors like the following happen:
2018-09-30 11:08:26.192 [INFO ] [org.openhab.binding.fritzboxtr064 ] - FrameworkEvent INFO - org.openhab.binding.fritzboxtr064
java.io.IOException: Exception in opening zip file: /var/lib/openhab2/cache/org.eclipse.osgi/222/0/.cp/lib/httpclient-win-4.4.1.jar
...rest of stack trace...
Caused by: java.io.FileNotFoundException: /var/lib/openhab2/cache/org.eclipse.osgi/222/0/.cp/lib/httpclient-win-4.4.1.jar (No such file or directory)
full openhab.log: openhab.log - Pastebin.com
This happens with other files too, like:
- httpcore-4.4.1.jar
- commons-codec-1.9.jar
- commons-logging-1.2.jar
- fluent-hc-4.4.1.jar
Whats the problem here?
I already tried to delete everything in /var/lib/openhab2/cache/* and /var/lib/openhab2/tmp/*, and also tried the same in a docker container running openhab instead of Ubuntu.
Hopefully someone may help me, the temperatures are getting lower and I don’t want to set my heating manually ![]()
