I use the avmfritz binding for my thermostats and sockets. The sockets FritzDECT200 also work so far except that the status is not updated when I switch on the unit itself. There is no event in the logs. If I switch on or off via openHAB app or the official app everything works.
Just tested with one of my FRITZ!DECT 200 devices: it works - events are fired up.
Environment: FRITZ!Box 7490 Firmware: 07.21, FRITZ!DECT 200 Firmware 04.16, OpenHAB 3.1.0 Build #2222
thank you for the report.
Environment: FRITZ!Box 6591 Firmware: 07.13, FRITZ!DECT 200 Firmware 04.16, OpenHAB 3.1.0 Build #2222
i had to re-add them to the box now they work.
