- Platform information:
Raspberry pi 4- openHAB version: 3.3.0
- Issue of the topic: frontail connection refused after update to 3.3.0
- Please post configurations (if applicable):
Yesterday I switched from Pi3 to Pi4 and updated openhab inside of openhabian-config.
This morning i tried to open the log viewer but it says connection refused.
There are several topics regarding this and I also had to solve this issue before, but this time I cant make it run again.
Installation is failing when I start it from openhabian-config:
Installing Frontail prerequsites (NodeJS)… FAILED
NodeJs version is 14.21.1-deb-1nodesource1
When i check the status of frontail its showing the following:
openhabian@openHABianDevice:~ $ systemctl status frontail.service
● frontail.service - Frontail openHAB instance, reachable at http://openHABianDevice:9001
Loaded: loaded (/etc/systemd/system/frontail.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2022-11-11 08:49:25 CET; 1s ago
Docs: https://github.com/mthenw/frontail
Main PID: 7340 (node)
Tasks: 7 (limit: 3839)
CGroup: /system.slice/frontail.service
└─7340 node /usr/lib/node_modules/frontail/bin/frontail --disable-usage-stats --ui-highlight --ui-highlight-preset /usr/lib/node_modules/frontail/
Nov 11 08:49:25 openHABianDevice systemd[1]: Started Frontail openHAB instance, reachable at http://openHABianDevice:9001.
Dont know why it tells me its reachable under http://openHABianDevice:9001 even if the network name is “openhab”.
Also the journal shows its continously starting and stopping
openhabian@openHABianDevice:~ $ sudo journalctl -u frontail
-- Logs begin at Fri 2022-11-11 07:55:09 CET, end at Fri 2022-11-11 08:50:59 CET. --
Nov 11 07:55:33 openHABianDevice systemd[1]: Started Frontail openHAB instance, reachable at http://openHABianDevice:9001.
Nov 11 07:55:42 openHABianDevice systemd[1]: frontail.service: Main process exited, code=exited, status=1/FAILURE
Nov 11 07:55:42 openHABianDevice systemd[1]: frontail.service: Failed with result 'exit-code'.
Nov 11 07:55:42 openHABianDevice systemd[1]: frontail.service: Service RestartSec=100ms expired, scheduling restart.
Nov 11 07:55:42 openHABianDevice systemd[1]: frontail.service: Scheduled restart job, restart counter is at 1.
Nov 11 07:55:42 openHABianDevice systemd[1]: Stopped Frontail openHAB instance, reachable at http://openHABianDevice:9001.
Nov 11 07:55:42 openHABianDevice systemd[1]: Started Frontail openHAB instance, reachable at http://openHABianDevice:9001.
Nov 11 07:55:45 openHABianDevice systemd[1]: frontail.service: Main process exited, code=exited, status=1/FAILURE
Nov 11 07:55:45 openHABianDevice systemd[1]: frontail.service: Failed with result 'exit-code'.
Nov 11 07:55:45 openHABianDevice systemd[1]: frontail.service: Service RestartSec=100ms expired, scheduling restart.
Nov 11 07:55:45 openHABianDevice systemd[1]: frontail.service: Scheduled restart job, restart counter is at 2.
Nov 11 07:55:45 openHABianDevice systemd[1]: Stopped Frontail openHAB instance, reachable at http://openHABianDevice:9001.
Nov 11 07:55:45 openHABianDevice systemd[1]: Started Frontail openHAB instance, reachable at http://openHABianDevice:9001.
Nov 11 07:55:48 openHABianDevice systemd[1]: frontail.service: Main process exited, code=exited, status=1/FAILURE
Nov 11 07:55:48 openHABianDevice systemd[1]: frontail.service: Failed with result 'exit-code'.
Any ideas?
