Peacemaker
(Bjorn Vandeuren)
February 1, 2021, 4:01pm
1
Hi, i found a article and did not know if i have to reply over there or make a new one, because its solved already.
I’ll move this if needed.
But i migrated to OH3 with my RPI 3B+, all is reasonably fine, all my devices are working.
But i did notice the Frontail is stuck on the date i migrated.
Then i found this article:
Here ist my frontail.service - the only change I did was from /openhab2/ to /openhab/
[Unit]
Description=Frontail
Documentation=https://github.com/mthenw/frontail
Documentation=https://github.com/openhab/openhabian/issues/28
After=openhab.service
[Service]
Type=simple
ExecStart=/usr/bin/frontail -t dark --ui-highlight --ui-highlight-preset /usr/lib/node_modules/frontail/preset/openhab.json -l 2000 /var/log/openhab/openhab.log /var/log/openhab/events.log
Restart=always
User=openhab
Gro…
so i searched this file:
/etc/systemd/system/frontail.service
i removed the “2” here and here:
i then restarted OH service, but this did not reload the Frontail
crazely typed: sudo service frontail restart, thought might as well try , no idea if this even exists…
and recieved this:
either way my Frontail is not working yet, but this message worries me more now.
Any help is appreciated.
Thank you
ndye
(Ethan Dye)
February 1, 2021, 4:04pm
2
You should use sudo openhabian-config
menu option 21 to reinstall as it will automatically solve the issue.
Peacemaker
(Bjorn Vandeuren)
February 1, 2021, 4:06pm
3
Hello @ndye Thank you for the input.
Testing as we speak.
Peacemaker
(Bjorn Vandeuren)
February 1, 2021, 4:09pm
4
@ndye working perfectly, thank you!
