[Frontail] Problems with installation
Hi There, Im using ubuntu with openhabian and have problems with the log viewer installation. The service isnt starting because of a missing template file. This is what the installation is throwing:
$ npm install -g frontail
/usr/local/bin/frontail -> /usr/local/lib/node_modules/frontail/bin/frontail
+ frontail@4.5.0
updated 1 package in 2.981s
$ npm update -g frontail
cp: reguläre Datei '/usr/lib/node_modules/frontail/preset/openhab.json' kann nicht angelegt werden: Datei oder Verzeichnis nicht gefunden
cp: reguläre Datei '/usr/lib/node_modules/frontail/web/assets/styles/openhab.css' kann nicht angelegt werden: Datei oder Verzeichnis nicht gefunden
Thanx for advice!
did you setup frontail using the openHABian config tool ?
it performs the following:
Yes i used the openhabian config tool for installation. I have no idea what to do to get the log viewer working. the service isnt starting without the preset.
yeah, I think (may be wrong) there are some issues with the frontail in openHABian currently. I will try to open up a PR to fix them.
download the required files as follows:
wget "https://raw.githubusercontent.com/openhab/openhabian/master/includes/frontail-theme.css" -O /usr/lib/node_modules/frontail/web/assets/styles/openhab2.css
wget "https://raw.githubusercontent.com/openhab/openhabian/master/includes/frontail-preset.json" -O /usr/lib/node_modules/frontail/preset/openhab2.json
if this doesn’t work, let me know and I can give you some more examples on the service file also
The Problem is that i have not this directory. Maybe there is a problem with nodejs?
could be… try to re-install it with:
apt-get update && apt-get install nodejs  //for nodejs
npm i frontail -g  //for frontail
I am running npm v11.2.0 and it works fine with frontail (v4.5.0)
That does not help. But i got it. The path were wrong
I have a path
/usr/local/lib/node_modules/frontail/preset/
instead of
I changed the frontail_basedir in the nodejs-apps.sh script and updated the frontail.service
Additionally frontail did not start with “/usr/bin/frontail” so i changed it to “frontail”
Dont know why this is different at my installation.
I reported it on Github here Frontail installation issues · Issue #431 · openhab/openhabian · GitHub
However, if you’ve got any further details, or have managed to fix it, it’d be great for a PR to be submitted :slight_smile:
I think that the problem is that debian repos provide an old version of npm (2.x)
to update, I have added the following repo:
deb https://deb.nodesource.com/node_11.x jessie main
deb-src https://deb.nodesource.com/node_11.x jessie main
(this is for Debian 8, for 9 change to jessie to stretch)
Ref: distributions/README.md at master · nodesource/distributions · GitHub
Looks like i have already the newsest version installed and fixed it manually.
