I finally got my CUL working with OH2 on my QNAP to control my FS20 switches.
Everything is working well with normal Switches - power on/off is easy to control
However I got a problem to control the shutters with RSU switch.
ON click start shutter going UP, OFF going DOWN.
To stop the moving shutter you need to click the same direction again.
This however is not working. Either the shutter is going UP till the end position, or DOWN to the end position, however I cannot stop it in between
This setup is a problem as I cannot really control the shutter behavior.
The shutter is either going UP or DOWN completely, but I cannot stop it in between anymore.
I found some comments in FHEM wiki about this RSU behavior and the workaround to apply.
However I don’t know how to do it in OpenHAB
Ideally I should have 2 Buttons, one Button for UP, and another for DOWN.
When the UP button is clicked, the shutter should go UP until the UP button is pushed again.
Same for the DOWN button.
When using a switch OH will alternate between sending ON and OFF. In your case I would use a raw command for an explicit (and only) ON button and an explicit OFF button. I’m not using the FS20 commands, however you should be able to see the actual (raw) commands in the log (hoping, not knowing!)
Don’t think you can use Rollershutter with FS20 and CUL but Switch and Dimmer items only.
I did the following to make my setup work.
Hope this helps to adapt your rollershutter setup, but maybe someone else can provide a better approach for your requirements
