- Platform information:
- Hardware: RPi2
- OS: OpenHabian
- Java Runtime Environment: 1.8.0_152
- openHAB version: 2.4.0-1
I’m using OpenHab with FS20 and Sonos Binding, but after some days or sometimes weeks, the FS20 Binding stops working. I see messages like
“2019-01-05 19:31:39.105 [DEBUG] [ab.binding.fs20.internal.FS20Binding] - Received command ON for item fs20_SWITCH_wohnzimmer_chillbeleuchtung”
in the log, but cannot find any errors that might give a hint.
I tried “log:set DEBUG org.openhab.binding.fs20” which did not give much more Information and then tried “log:set DEBUG”, but I also couldn’t find any messages that look suspicious to me - but maybe I missed something relevant in the noise…
I use https://www.ebay.de/itm/nanoCUL-USB-Stick-FTDI-CC1101-868MHz-FW-1-67-FHEM-CCU-CUL-868-inkl-Adapter/372216852633?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 as FS20 Transceiver and my /etc/openhab2/services/fs20.cfg looks like:
device=serial:/dev/serial/by-id/usb-SHK_NANO_CUL_868-if00-port0
baudrate=38400
parity=NONE
The Sonos-Binding works fine while the FS20 problems are present. After restarting openhab with “sudo systemctl restart openhab2” the fs20 binding works again.
Would be great if someone can give me a hint, how to trace the problem!
Thanks a lot and best regards,
Frank
