Conf: RBpi 3B+, OH2 latest version, KNX and HomeKit Bindings
I have two Fujitsu AC machines installed at home. I would like to know if it is possible to have the integration in HomeKit binding of an IR transmitter with pre-setted Fujitsu frequency . I looked for RM pro or Zmote solutions (but they doesn’t seem to have a binding). Is there an alternative solutions to this product?
Thanks in advance
I think (I am not sure since I don’t use it): For the Broadlink RM Pro you have 2 options to integrate in OH2:
a) RM -> MQTT Bridge -> MQTT Broker -> OH2. One example is: https://github.com/fbacker/broadlink-mqtt-bridge
unfortunately my AC is not smart, but I would like to be able to turn it on via homekit. I think HK does not allow other parameters to be set. but if I install a binding in oh2, then can I find it in HK?
Thank you
You can have a [ "Switchable" ] tagged OH2 Item that is exposed to HK and you can use HK (selections, voice commands, scenes, etc) to turn the AC ON/OFF. The OH2 bound Item would trigger the InfraRed Remote Controller which will send the ON/OFF signal to the AC unit.
I believe that the same applies for setting the temperature for example (using a [ "Thermostat" ] tag?)
