This library is a collection of all Ephemeris Actions Examples from the Documentation Page
If one use this library, follow the examples from the documentation and follow the syntax order.
Blocks
The screenshots are in the same order as the documentation and show the possible inputs.
Changelog
Version 0.1
- initial release
Resources
uid: ephemeris all
tags: []
props:
parameters: []
parameterGroups: []
component: BlockLibrary
slots:
blocks:
- component: BlockType
args0:
- name: variety
options:
- - getBankHolidayName
- - getNextBankHoliday
- - isBankHoliday
- isBankHoliday
- - isWeekend
- isWeekend
type: field_dropdown
colour: 0
helpUrl: ""
inputsInline: true
message0: "%1"
output: ""
type: Ephemeris zero input
slots:
code:
- component: BlockCodeTemplate
template: "{{utility:Ephemeris}}.{{field:variety}}()"
args0:
- name: eph
type: input_value
check: ephemeris
colour: 0
helpUrl: ""
inputsInline: true
message0: get holidayDescription %1
output: ""
tooltip: ""
type: holidayDescription
slots:
code:
template: "{{utility:Ephemeris}}.getHolidayDescription({{input:eph}})"
args0:
- name: variety
options:
- - getDaysUntil
- getDaysUntil
- - isBankHoliday
- isBankHoliday
- - isInDayset
- isInDayset
- - isWeekend
- isWeekend
- name: multi
type: input_value
colour: 0
helpUrl: ""
inputsInline: true
message0: "%1 offset, datetime, text or file%2"
output: ""
tooltip: for input sequence one must follow the documentation ephemeris actions examples
type: Ephemeris one input
slots:
code:
template: "{{utility:Ephemeris}}.{{field:variety}}({{input:multi}})"
args0:
- name: variety
options:
- - getDaysUntil
- getDaysUntil
- - isBankHoliday
- isBankHoliday
- - isInDayset
- isInDayset
- name: multi
type: input_value
- name: multi2
type: input_value
colour: 0
helpUrl: ""
inputsInline: true
message0: "%1 offset, datetime or text %2 datetime, text or file %3"
output: ""
type: Ephemeris two input
slots:
code:
template: "{{utility:Ephemeris}}.{{field:variety}}({{input:multi}},{{input:multi2}})"
args0:
- name: datetime
type: input_value
- name: name
type: input_value
- name: file
type: input_value
colour: 0
helpUrl: ""
inputsInline: true
message0: get days until, from %1 holiday name %2 file %3
output: ""
type: getDaysUntil
slots:
code:
template: "{{utility:Ephemeris}}.getDaysUntil({{input:datetime}},{{input:name}},{{input:file}})"
toolbox:
- component: PresetInput
fields:
TEXT: path_to_file
shadow: true
type: text
fields:
TEXT: Holiday_Name
shadow: true
type: text
shadow: true
type: oh_zdt
utilities:
- component: UtilityJavaType
javaClass: org.openhab.core.model.script.actions.Ephemeris
