When the rule runs, the timer created successfully, but when the timer runs, it looks like it does not recognize the relayItem. here is the error:
2017-05-14 23:14:15.181 [ERROR] [org.quartz.core.JobRunShell ] - Job DEFAULT.2017-05-14T23:14:15.165+03:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
logInfo(,)
org.eclipse.xtext.xbase.impl.XIfExpressionImpl@6cb7d7
} ] threw an unhandled Exception:
java.lang.RuntimeException: The name ‘.sendCommand()’ cannot be resolved to an item or type.
at org.eclipse.smarthome.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:112)[129:org.eclipse.smarthome.model.script:0.9.0.b4]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:763)[145:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:219)[145:org.eclipse.xtext.xbase:2.9.2.v20160428-1452]
That sounds like a situation in which the Expire Binding could be used. Please have a look at the following thread. @rlkoshak explains the usage at the bottom of the first post. Design Pattern: Motion Sensor Timer
No…
I simplified the problem. My rules are much smarter with lots of conditions (not always turn off the light… and if they turn off the light it depends on the time…)
