No idea. Don’t they represent your dustbin collection days? Maybe you can use Habmin to assign some initial values (the persistence saves you from doing that at every reboot).
As far as I know the items gets values from my Google calendar
Hi all,
if I remember correctly, we already checked via PM that the “unsorted” date items have values (should be checked again). My rule (wich might not be good code, I started with OH only a few months ago) uses 4 garbage items. As you reduced it to 3, I think there might be mixed up something. Maybe a “rest” of the 4th item is used somewhere (probably in the sorting part). But as I’m on holiday at the moment, I don’t have good possibilities to check this.
But I recommend the same as @opus and as I already did via PM: place logInfos in every interesting line schould help you to find the bug.
this was the rule:
rule "Abfalltermine sortieren"
Item Restmuell received update or
Item Biomuell received update or
Item Papiermuell received update or
Item RaWeg received update or
Item RestmuellTage changed or
Item PapiermuellTage changed or
Item BiomuellTage changed or
Item RaWegTage changed or
//Time cron "0 8 0 1/1 * ? *" or
Item DelayedStartup changed from OFF to ON
Thread::sleep(3000)
var DateTime varTempDatum
var DateTime varAbfall1Datum = new DateTime((Restmuell.state as DateTimeType).zonedDateTime.toInstant.toEpochMilli)
var DateTime varAbfall2Datum = new DateTime((Biomuell.state as DateTimeType).zonedDateTime.toInstant.toEpochMilli)
var DateTime varAbfall3Datum = new DateTime((Papiermuell.state as DateTimeType).zonedDateTime.toInstant.toEpochMilli)
var DateTime varAbfall4Datum = new DateTime((RaWeg.state as DateTimeType).zonedDateTime.toInstant.toEpochMilli)
var String varTempArt
var String varAbfall1Art = "Restmuell"
var String varAbfall2Art = "Biomuell"
var String varAbfall3Art = "Papiermuell"
var String varAbfall4Art = "RaWeg"
var String varTempTage
var String varAbfall1Tage = RestmuellTage.state.toString
var String varAbfall2Tage = BiomuellTage.state.toString
var String varAbfall3Tage = PapiermuellTage.state.toString
var String varAbfall4Tage = RaWegTage.state.toString
var i = 1
while ((i=i+1) < 6) {
if (varAbfall1Datum > varAbfall2Datum) {
varTempDatum = varAbfall1Datum
varAbfall1Datum = varAbfall2Datum
varAbfall2Datum = varTempDatum
varTempArt = varAbfall1Art
varAbfall1Art = varAbfall2Art
varAbfall2Art = varTempArt
varTempTage = varAbfall1Tage
varAbfall1Tage = varAbfall2Tage
varAbfall2Tage = varTempTage
if (varAbfall2Datum > varAbfall3Datum) {
varTempDatum = varAbfall2Datum
varAbfall2Datum = varAbfall3Datum
varAbfall3Datum = varTempDatum
varTempArt = varAbfall2Art
varAbfall2Art = varAbfall3Art
varAbfall3Art = varTempArt
varTempTage = varAbfall2Tage
varAbfall2Tage = varAbfall3Tage
varAbfall3Tage = varTempTage
if (varAbfall3Datum > varAbfall4Datum) {
varTempDatum = varAbfall3Datum
varAbfall3Datum = varAbfall4Datum
varAbfall4Datum = varTempDatum
varTempArt = varAbfall3Art
varAbfall3Art = varAbfall4Art
varAbfall4Art = varTempArt
varTempTage = varAbfall3Tage
varAbfall3Tage = varAbfall4Tage
varAbfall4Tage = varTempTage
Abfall_1_Datum.postUpdate(varAbfall1Datum.toString)
Abfall_2_Datum.postUpdate(varAbfall2Datum.toString)
Abfall_3_Datum.postUpdate(varAbfall3Datum.toString)
Abfall_4_Datum.postUpdate(varAbfall4Datum.toString)
Abfall_1_Art.postUpdate(varAbfall1Art)
Abfall_2_Art.postUpdate(varAbfall2Art)
Abfall_3_Art.postUpdate(varAbfall3Art)
Abfall_4_Art.postUpdate(varAbfall4Art)
Abfall_1_Tage.postUpdate(varAbfall1Tage)
Abfall_2_Tage.postUpdate(varAbfall2Tage)
Abfall_3_Tage.postUpdate(varAbfall3Tage)
Abfall_4_Tage.postUpdate(varAbfall4Tage)
because I only have 3 types of waste. I deleted ‘RaWeg’ , ‘varAbfall4Art’, ‘varAbfall4Tage’ and ‘varAbfall4Datum’. But I think I made a mistake somewhere.
Now I have this rule:
Thread::sleep(3000)
var i = 1
logInfo("Afval.rules", "varTempDatum" +varTempDatum)
logInfo("Afval.rules", "varAbfall1Datum" +varAbfall1Datum)
logInfo("Afval.rules", "varAbfall2Datum" +varAbfall2Datum)
logInfo("Afval.rules", "varAbfall3Datum" +varAbfall3Datum)
logInfo("Afval.rules", "varTempArt" +varTempArt)
logInfo("Afval.rules", "varAbfall1Art" +varAbfall1Art)
logInfo("Afval.rules", "varAbfall3Art" +varAbfall3Art)
logInfo("Afval.rules", "varTempTage" +varTempTage)
logInfo("Afval.rules", "varAbfall1Tage" +varAbfall1Tage)
logInfo("Afval.rules", "varAbfall2Tage" +varAbfall2Tage)
logInfo("Afval.rules", "varAbfall3Tage" +varAbfall3Tage)
I think I deleted to much at the comparison part. Can someone look at my rule and tell me what I did wrong and how I can solve this?
