I’ve a rule for my garbage. But I get an error. But I couldn’t figure out what is caussing the error.
Can someone look at my rule?
rule "Tage bis Abfall berechnen"
Time cron "0 5 * 1/1 * ? *" or
Item Restmuell changed or
Item Biomuell changed or
Item Papiermuell changed or
Item DelayedStartup changed from OFF to ON
logInfo("all.rules", "Tage bis Abfall berechnen")
//Restmuell
val DateTime varRestmuellDatum = new DateTime((Restmuell.state as DateTimeType).zonedDateTime.toInstant.toEpochMilli).withTimeAtStartOfDay
val Long varRestmuellDiff = Math::round((varRestmuellDatum.millis - now.withTimeAtStartOfDay.millis) / (86400000.0))
if ( varRestmuellDiff == 0 ) {
RestmuellTage.postUpdate("heute")
} else if ( varRestmuellDiff == 1 ) {
RestmuellTage.postUpdate("morgen")
} else {
RestmuellTage.postUpdate(String::format("(%1$d T.)", varRestmuellDiff))
//Biomuell
val DateTime varBiomuellDatum = new DateTime((Biomuell.state as DateTimeType).zonedDateTime.toInstant.toEpochMilli).withTimeAtStartOfDay
val Long varBiomuellDiff = Math::round((varBiomuellDatum.millis - now.withTimeAtStartOfDay.millis) / (86400000.0))
if ( varBiomuellDiff == 0 ) {
BiomuellTage.postUpdate("heute")
} else if ( varBiomuellDiff == 1 ) {
BiomuellTage.postUpdate("morgen")
} else {
BiomuellTage.postUpdate(String::format("(%1$d T.)", varBiomuellDiff))
//Papiermuell
val DateTime varPapiermuellDatum = new DateTime((Papiermuell.state as DateTimeType).zonedDateTime.toInstant.toEpochMilli).withTimeAtStartOfDay
val Long varPapiermuellDiff = Math::round((varPapiermuellDatum.millis - now.withTimeAtStartOfDay.millis) / (86400000.0))
if ( varPapiermuellDiff == 0 ) {
PapiermuellTage.postUpdate("heute")
} else if ( varPapiermuellDiff == 1 ) {
PapiermuellTage.postUpdate("morgen")
} else {
PapiermuellTage.postUpdate(String::format("(%1$d T.)", varPapiermuellDiff))
rule "Abfalltermine sortieren"
Item Restmuell received update or
Item Biomuell received update or
Item Papiermuell received update or
Item RaWeg received update or
Item RestmuellTage changed or
Item PapiermuellTage changed or
Item BiomuellTage changed or
Item RaWegTage changed or
//Time cron "0 8 0 1/1 * ? *" or
Thread::sleep(3000)
var DateTime varTempDatum
var DateTime varAbfall1Datum = new DateTime((Restmuell.state as DateTimeType).zonedDateTime.toInstant.toEpochMilli)
var DateTime varAbfall2Datum = new DateTime((Biomuell.state as DateTimeType).zonedDateTime.toInstant.toEpochMilli)
var DateTime varAbfall3Datum = new DateTime((Papiermuell.state as DateTimeType).zonedDateTime.toInstant.toEpochMilli)
var String varTempArt
var String varAbfall1Art = "Restmuell"
var String varAbfall2Art = "Biomuell"
var String varAbfall3Art = "Papiermuell"
var String varTempTage
var String varAbfall1Tage = RestmuellTage.state.toString
var String varAbfall2Tage = BiomuellTage.state.toString
var String varAbfall3Tage = PapiermuellTage.state.toString
logInfo("Afval.rules", "varAbfall1Datum: " +varAbfall1Datum)
logInfo("Afval.rules", "varAbfall1Tage: " +varAbfall1Tage)
logInfo("Afval.rules", "varAbfall2Datum: " +varAbfall2Datum)
logInfo("Afval.rules", "varAbfall2Tage: " +varAbfall2Tage)
logInfo("Afval.rules", "varAbfall3Datum: " +varAbfall3Datum)
logInfo("Afval.rules", "varAbfall3Tage: " +varAbfall3Tage)
var i = 1
while ((i=i+1) < 6) {
if (varAbfall1Datum > varAbfall2Datum) {
varTempDatum = varAbfall1Datum
varAbfall1Datum = varAbfall2Datum
varAbfall2Datum = varTempDatum
varTempArt = varAbfall1Art
varAbfall1Art = varAbfall2Art
varAbfall2Art = varTempArt
varTempTage = varAbfall1Tage
varAbfall1Tage = varAbfall2Tage
varAbfall2Tage = varTempTage
if (varAbfall2Datum > varAbfall3Datum) {
varTempDatum = varAbfall2Datum
varAbfall2Datum = varAbfall3Datum
varAbfall3Datum = varTempDatum
varTempArt = varAbfall2Art
varAbfall2Art = varAbfall3Art
varAbfall3Art = varTempArt
varTempTage = varAbfall2Tage
varAbfall2Tage = varAbfall3Tage
varAbfall3Tage = varTempTage
Abfall_1_Datum.postUpdate(varAbfall1Datum.toString)
Abfall_2_Datum.postUpdate(varAbfall2Datum.toString)
Abfall_3_Datum.postUpdate(varAbfall3Datum.toString)
Abfall_1_Art.postUpdate(varAbfall1Art)
Abfall_2_Art.postUpdate(varAbfall2Art)
Abfall_3_Art.postUpdate(varAbfall3Art)
Abfall_1_Tage.postUpdate(varAbfall1Tage)
Abfall_2_Tage.postUpdate(varAbfall2Tage)
Abfall_3_Tage.postUpdate(varAbfall3Tage)
rule "Abfall steht an - Blinkeding"
Time cron "0 0 17 1/1 * ? *"
if (Abfall_1_Tage.state.toString == "morgen") {
Abfall_Steht_An.postUpdate(ON)
rule "Abfall steht an - Informiere Jochen"
Time cron "0 30 20 1/1 * ? *"
if (Abfall_Steht_An.state == ON ) {
sendTelegram("Jeroen", "%s moet je nog buiten zetten", Abfall_1_Art.state.toString)
rule "Abfall steht an - Informiere -Frau- und Jochen"
Time cron "0 30 21 1/1 * ? *"
if (Abfall_Steht_An.state == ON) {
sendTelegram("Jeroen ", "Oh je, %s staat nog steeds niet aan straat!", Abfall_1_Art.state.toString)
sendTelegram("Jeroen", "%s staat nog niet aan straat, schiet nou eens op", Abfall_1_Art.state.toString)
this is my log:
2018-09-08 00:44:52.817 [INFO ] [e.smarthome.model.script.Afval.rules] - varAbfall1Datum: 2018-09-12T00:00:00.000+02:00
2018-09-08 00:44:52.818 [INFO ] [e.smarthome.model.script.Afval.rules] - varAbfall1Datum: 2018-09-12T00:00:00.000+02:00
2018-09-08 00:44:52.825 [INFO ] [e.smarthome.model.script.Afval.rules] - varAbfall1Tage: (4 T.)
2018-09-08 00:44:52.826 [INFO ] [e.smarthome.model.script.Afval.rules] - varAbfall1Tage: (4 T.)
2018-09-08 00:44:52.831 [INFO ] [e.smarthome.model.script.Afval.rules] - varAbfall2Datum: 2018-09-19T00:00:00.000+02:00
2018-09-08 00:44:52.836 [INFO ] [e.smarthome.model.script.Afval.rules] - varAbfall2Datum: 2018-09-19T00:00:00.000+02:00
2018-09-08 00:44:52.836 [INFO ] [e.smarthome.model.script.Afval.rules] - varAbfall1Tage: (4 T.)
2018-09-08 00:44:52.837 [INFO ] [e.smarthome.model.script.Afval.rules] - varAbfall2Tage: (11 T.)
2018-09-08 00:44:52.844 [INFO ] [e.smarthome.model.script.Afval.rules] - varAbfall2Datum: 2018-09-19T00:00:00.000+02:00
2018-09-08 00:44:52.844 [INFO ] [e.smarthome.model.script.Afval.rules] - varAbfall3Datum: 2018-09-26T00:00:00.000+02:00
2018-09-08 00:44:52.844 [INFO ] [e.smarthome.model.script.Afval.rules] - varAbfall2Tage: (11 T.)
2018-09-08 00:44:52.850 [INFO ] [e.smarthome.model.script.Afval.rules] - varAbfall2Tage: (11 T.)
2018-09-08 00:44:52.850 [INFO ] [e.smarthome.model.script.Afval.rules] - varAbfall3Datum: 2018-09-26T00:00:00.000+02:00
2018-09-08 00:44:52.857 [INFO ] [e.smarthome.model.script.Afval.rules] - varAbfall3Datum: 2018-09-26T00:00:00.000+02:00
2018-09-08 00:44:52.857 [INFO ] [e.smarthome.model.script.Afval.rules] - varAbfall3Tage: (18 T.)
2018-09-08 00:44:52.864 [INFO ] [e.smarthome.model.script.Afval.rules] - varAbfall3Tage: (18 T.)
2018-09-08 00:44:52.866 [INFO ] [e.smarthome.model.script.Afval.rules] - varAbfall3Tage: (18 T.)
2018-09-08 00:44:52.910 [ERROR] [ntime.internal.engine.RuleEngineImpl] - Rule 'Abfalltermine sortieren': An error occurred during the script execution: null
