Has anyone managed to control the water computer (i.e. turning water on/off) using the binding? If they have, would you mind posting Thing and Item definitions, and an example rule/sitemap? Would be much appreciated.
thanks,
Dan
thanks,
Dan
Thing:
Bridge gardena:account:home [ email="...", password="..." ]
Thing watering_computer wasserhahn [ deviceId="..." ]
Some Items:
DateTime Wasserhahn_Zuletzt_Online "Zuletzt Online [%1$td.%1$tm.%1$tY %1$tH:%1$tM]" { channel="gardena:watering_computer:home:wasserhahn:device_info#last_time_online"}
Number Wasserhahn_Batterie "Batterie [%d %%]" { channel="gardena:watering_computer:home:wasserhahn:battery#level"}
Switch Wasserhahn_Ventil "Ventil" { channel="gardena:watering_computer:home:wasserhahn:outlet#valve_open"}
Number Wasserhahn_Dauer "Dauer [%d min]" { channel="gardena:watering_computer:home:wasserhahn:outlet#button_manual_override_time"}
Number Wasserhahn_Temperatur "Temperatur [%d °]" <temperature> { channel="gardena:watering_computer:home:wasserhahn:ambient_temperature#temperature"}
Rule: you always have to send the duration first, e.g 30 minutes:
sendCommand(Wasserhahn_Dauer, 30)
sendCommand(Wasserhahn_Ventil, ON)
brilliant - thank you!
First of all, thanks for all the time you put into the binding!
Can you tell me
What is the meaning of the values of " Signal Strength" ? I saw values of 0-2 for radio#state. Do you know their meanings?
You mentioned “Some Items:” above. On discovery paper UI only shows
You are addionally mentioning
Is this the complete list or are there more?
Thanks in advance,
Stefan
