Since the last Gardena update I get the following error:
2019-06-07 07:56:32.602 [WARN ] [internal.handler.GardenaThingHandler] - Channel 'gardena:ic24:068c258a:3c55553e-xxxx-xxxx-xxxx-xxxxxxx:ic24#error' cannot be updated as device does not contain property 'ic24:error'
This message pops up for all 6 valves every minute.
I am running OpenHAB 2.5.0 M1.
Anybody with the same issue / solution?
Exactly same problem here, already since 2019-06-03 14:42:54.193. Could be a Gardena automatic update but it was definitely not me who updated. I am running Gardena Gateway Version 3.4.10 right now and openHAB 2.4.0-1 (Release Build).
I have the same problem. and the valves 1-6 have also an error
2019-06-08 11:12:45.811 [WARN ] [internal.handler.GardenaThingHandler] - Channel āgardena:ic24:fba27386:ce629634-70a5-413e-acf1-fd17872bfc0e:ic24#valve_error_0ā cannot be updated as device does not contain property āic24:valve_error_0ā
New watering season, same problemā¦
I updated openHAB to 2.5.3, the error is still there and now I cannot control the valves at all anymore. Did anybody find a solution by now?
And itās getting worth :-/ As I just have made a Firmware Update to my Water Control and usually this improves devices! But Gardena obvioulsy changes also in this device as 5 channels are broken now
Is anyone still working on this Binding??
Currently Iām e.g. not able to start an irrigation any longer
Hi, I am new 2 openhabā¦
did a brand new install of openhabian on Raspi 4b usind Gardena Binding.
I can discover all the sensors and velves but they have less options available.
I also get those WANINGS:
Example1
2020-05-06 06:52:00.314 [WARN ] [internal.handler.GardenaThingHandler] - Channel āgardena:ic24:6357ac4e:c302104b-a6fd-44e4-8ab7-5799eaa76030:ic24#errorā cannot be updated as device does not contain property āic24:errorā
Example2
2020-05-06 06:52:00.360 [WARN ] [internal.handler.GardenaThingHandler] - Channel āgardena:watering_computer:6357ac4e:589d235b-fd1b-4a99-85cb-a146a145cf3b:outlet#manual_overrideā cannot be updated as device does not contain property āoutlet:manual_overrideā
But there are many more.
It is possible to read the values from the humitidy sensors and display them, but did not manage to open valvesā¦
May be this is somehow related ⦠my binding in IFTT is logged out not again and again. Is openhabian quering to fast?
