After adding more components to my Gardena Smart System, suddenly the binding is throwing this error:
'gardena:account:home' changed from OFFLINE (COMMUNICATION_ERROR): java.lang.IllegalStateException: Expected a string but was BEGIN_OBJECT at line 1 column 26065 path $.devices[3].abilities[2].properties[0].value to OFFLINE (COMMUNICATION_ERROR): java.lang.IllegalStateException: Expected a string but was BEGIN_OBJECT at line 1 column 26064 path $.devices[3].abilities[2].properties[0].value
Also on a fresh installed OH 2.3 system the same error occured.
i’ve just installed the latest OpenHab Version and the Gardena Binding.
After i’ve configured the Home Account, it shows mit initializing, but after refresh, i get an Offline Status with an Error Message called: Status: OFFLINE - COMMUNICATION_ERROR java.lang.IllegalStateException: Expected a string but was BEGIN_OBJECT at line 1 column 41843 path $.devices[4].abilities[2].properties[0].value
I can see another error in the Log called: [WARN ] [.core.thing.binding.BaseThingHandler] - Handler GardenaAccountHandler tried updating the thing status although the handler was already disposed.
The update is not included in this release, i made the changes on 17.06. This file is from 03.04. I don’t use openHabian, so i don’t know the details, but you can try to add the newest gardena binding to the openhab addons folder and make sure it get’s loaded.
now i could switch through the openHABian System to openHAB 2.4.0~20180708221346-1 (Build #1309)
and installed the gardena binding version 2.4.0 snapshot. My Account is now online.
now i also implemented the things and items through the openHAB2 Homekit Plugin, and set the tags via REST APi. Everthing worsk fine.
Are you using the gardena binding with Apple Homekit Home.App?
If yes, is there also possible to setup for example a time to start the WaterControl. At the moment i can start and stop the WaterControl, but in the Gardena App you can setup minutes to open the valve for example 30 minutes or so.
Is this also possible?
And another qestion: If i turn the WaterControl on via HomeKit App and turn it off via Gardena App, the Homekit App still shows me that it’s on. Is it possible to refreh the status automatically?
Due your refresh problem: The Gardena Item always refreshes in the configured interval (Bridge). If the Homekit app does not show the correct status, it’s Homekit plugin issue.
thank you for your response.
I understand, so your configuration above is set in the homebridge.conf and not in openHAB2 Json DB?
Is it possible to send me the whole config, because i don’t really know what to do whith this little snipset
Another question: Do you also have a config for control the valves from the irrigation control?
Which config? The one from my previous post? This is only openHab (Items and a Rule snippet)
Regarding openHab i never use PaperUI, i have everything in things and items file.
Then please read the openHab docs, these are basic things.
Thank you for pointing to the current version of the binding. However, unfortunately, I do not find it on the linked website - there seem to be only full openHAB packages. Is it possible to install the latest version of the binding with the current stable version of openHAB? If so: What do I need to do? I do not want to switch to the snapshot openHAB releases, but want to stay with the stable ones.
Just download openhab-addons-2.4.0-SNAPSHOT.kar, rename .kar to .zip and extract the files. There you will find the gardena binding jar file that you need to copy to the addons folder.
Make sure the correct version is loaded via the karaf console:
bundle:list | grep Gardena
